To star with, I really like the flashlight, but the threads are puny. They are not going to last long. Other than that I dont think it has any major issues.
So I tried to mod it like others did, essentially by shorting a dedomed xm-l2 u4 or xp-l V6 emitter, and then went even further and tried to do something about the threads.
My solution is not the best, but works, so was worth trying.
First of all, the BOSS:
I decided to mod it so that I could open the flashlight from the tailcap, right where the handle is mounted. To protect the flimsy threads in the middle of the flashlight between the part that carries the battery and the reflector part. It is easier on the threads to to open it while holding the light tailcap and. Risk of cross-threading them is much lower.To be able to do that I had to figure out how to mount the switch. The only way I could think of was to make it removable. I mean the red fibre glass circle. To make it easier to secure it I had to reverse the cells and rewire them. Enough talk, let the pictures tell the whole story!
the springs from the tailcap PCB board were substituted for brass knobs from the driver
Since I tried to keep the driver I made another PCB circle from a piece of a PCB board.
I tossed the retaining ring as well, it was too fragile to keep in the flashlight. To do that, I had to put some copper on the contact board to get enough contact with the aluminum ring. I moved the aluminum ring that was under the driver right above my new contact board.
I needed to do some soldering, too.
all mounted together - the body screwed tight pushes sufficiently to keep the contact plate int the right position. No flimsy stupidly thin retaining ring is needed!!!
the cells now protrude from the tailcap end
to keep he original switch I had to figure out how to take it apart put it back together in every time I change the cells without too much hassle or damaging it. So I drilled 2 7mm holes right next to 2 original holes for screws and the filed the fibre glass in between. The screw heads now keep the switch plate in its place. It is 3mm thick, so solid enough not to break from the spring load. To replace the cells I have to unscrew the tailcap end, which is much easier on the threads, and then twist the switch plate from this
to this
and it pops out due the tension from the springs. Did I mention I reversed the cells? It is easier to manipulate with the switch plate with the brass knobs instead of the long springs, the springs would make it difficult and clumsy.
And most importantly the tailcap with the puny flimsy frail threads can be screwed to the body without any tension that would definitely destroy the threads sooner or later.
That saves me from unscrewing the body each single time I want to replace the cells.
To sum up, it is not the most user friendly and easiest mod, but there does not seem anything else one can do to protect the threads. My mod is not the most convenient and handiest to use, but it works, so it is all I need. I need a cheap thrower that will last for years, and this mod will surely significantly improve the life span of the threads, which are the greatest design flaw of this otherwise decent flashlight.
Beamshots will come later.
HOpe you like it and will draw some inspiration for your mods.
Any ideas or comments or improvements are welcome!
