I have a set of 9 LG DB118650 18650 cells pulled from a used laptop pack. If I remember correctly, these were pulled from a 4 year old well used Dell battery pack which the user said was giving him reduced runtime. I labeled all 9 cells 1 to 9, recorded initial pulled voltage, charged up, recorded full charge voltages, and then recorded voltages 2 weeks later and then 5 months later. 8 of the 9 are very consistent, with the 1 odd one just slightly different. Of those 8 I have chosen 1 to evaluate further and here are the stats:
Initial pulled voltage: 4.11v
Fully charged: 4.17v
16 days later: 4.15v
5 months later (today 1/6/2014): 4.13v
I don't have a Hobby charger, so I used my EDC Convoy S2 with a 2.1A Nanjg driver to do a discharge test. I Placed the cell without recharging into my Convoy S2 and measured tailcap current @ 2.03A and it held steady there. I then put the tailcap on, put the light on high, and ran a timer. At 15 minutes the light was burning hot so I placed a fan nearby blowing across it to continue.
At 45 minutes I stopped and measured cell voltage @ 3.68v and current @ 0.83A and falling (it actually started higher, but the drop slowed around 0.83A). Put cell back in light on high and continued the timer.
At 58 minutes the low voltage flash kicked in and I shut the light off, quickly removed battery and tested voltage @ 3.61v, tailcap current of 0.48A and dropping like a rock. I let the cell rest 5 minutes and rechecked voltage @ 3.69v.
Then for comparison I checked tailcap current with a used Sanyo laptop pull @ 3.75v and it gave me a very steady 2.03A.
I realize I should have stopped my test at maybe 15 & 30 minutes for voltage and current, but I didn't. In any case, what is your evaluation of this LG cell (and very likely the same condition with the other 7 or 8 I have)? Do you think it has enough capacity to be worth keeping? Or does it seem low enough to just toss them? Perhaps another good test would be to see what current the cells put out with my direct drive Manafont Ultrafire XM-L P60 drop-in? Is that a better test?
BTW, my thought was to use these LG's in my new ENB power bank / mobile charger.
Thanks,
Garry
