You objected due to your experience, and I was wondering (not wanting to clutter up the other thread) what beam widths you’ve tried?
I went with 60° because I absolutely do want FLOOD (all caps/shouting on purpose) and figure for my needs, a lot of flood will effectively “throw” light further than I need it anyway. So far, so good, but I am starting to notice the “back end” of the beam falls off quite a bit.
OTOH, I do “get it” (at least I like to tell myself I do) re: Throw & would like to build exactly what you’re posting about here, a “roll-of-coins” sized thrower, with a TIR. “For camping”, if SWMBO asks!
Could you opine on the “best” FWHM angle for “Throw Uber Alles” in a 20mm head? I’ve found a budget source & plan to try this, but he only sells 5 at a time & I’d rather not get stuck with 4 lumps of plastic if, say 5° is too tight to be useful or 10° doesn’t throw well. TBH, I’ve read every thread I can find on it & can’t make up my mind.
I tried a few TIR’s when I was first starting with lights, but I haven’t revisited them after I decided they weren’t for me. They’re great for making a smooth beam, but I’ve tried 10 and 15° and neither of them had really any throw compared to a smooth reflector. I’d love to be proven wrong though.
I put a dedomed xpg2 in a s3/t12 host. They have the short OP reflectors... i put a 4.5A driver in it and never braided or upgraded the driver spring so it's only at 3.4A, but I think it throws better than my s4 with a 6A driver doing 4.5A to an xml2. Both on noctigons.
im totally with you on finding the best combination of throwy vs size.
I’ve got a SMO P60 I put together with an XP-G2 driven by a 3.04A 105C and it throws a pretty tight hotspot especially when compared to my xml2 p60 and fenix pd35. It’s currently in a solarforce l2m.
Throw (as in: how bright is the hotspot) is caused by three things:
-reflector diameter How deep it is does not affect throw, it affects hotspot size and spill diameter
-reflector quality. High end lights tend to get more throw out of a given reflector diameter
-die surface brightness. Dedomed XP-E2 driven at max (2.5A) has the highest surface brightness (there's even a 'Torch' version now that is a little brighter even). Dedomed XP-G2 if driven at 5+A comes close. XM-L2 at any possible current does come close.
A well-performing AR-coated lens adds a bit of throw too.
Fits your criteria of 28MM, I just compared it to my Convoy S2 (Old style) and it is brighter and appears (indoors at least) to be the better thrower.
With an dedoomed XP-G2 it should give you what you desire. Maybe even just dedome the stock XM-L U2 for starters.
Stock the driver is High, Low, Strobe so that will probably have to go.
Good Luck with whatever you chose,
Nobody has mentioned the diameter of the hole at the base of the reflector. I think the wider base gives a shorter reflector better throw than a longer reflector with a narrow base. theres a pretty noticeable difference between a lot of the S series reflectors, the pills are different lengths too, and one or two are even different size threads, but everything can be interchanged with use of the right correlating parts.
You could be fooled: a distinct small hotspot suggests throw. It is the optical trick that many budget lights use. (I do not see an optical reason why a wide base would alter tbrow)
