NarsilM - configurable e-switch firmware for Multi channels, v1.3
I’ve got a light with NarsilM and one with v1.2.
I can’t get into strobe mode on the NarsilM light. I might have blinky modes turned off.
On the v1.2 light, I can only go backwards to the first strobe, then it stops.
I honestly don’t even know how many strobe modes are on there because I’ve never gone that far. I think at least five.
I hate blinky modes personally, but I’m still trying to figure them out because I want to do a video on narsil for the Q8 guys.
You can factory reset now in NarsilM, but of course that depends what your factory settings are. It sure gets confusing, even for me
The way I've been defaulting is all strobes enabled with the following set in order:
STROBE_MODE, POLICE_STROBE, BIKING_STROBE, BEACON_2S_MODE, BEACON_10S_MODE
2S is for 2 seconds, 10S for 10 seconds. This is the default Q8 setup, NarsilM v1.0.
So of you click thru to get to 2 sec beacon, then press&hold for biking (release the switch as soon as the mode switches), then press&hold again for police. Once you nav back, you can nav forward before the lock-in time.
Okay, yeah. I can go forward as well.
I just have to remember that once I get into the first strobe mode I can only click the button 4 times, any more than that will turn the light off. Also, if I try to reverse past the first strobe, it will turn off.
So now I just aim for the middle. 2 x 2 then 2 clicks. Then I have room to move backwards and forwards. Neat trick. Pretty complicated, though. Lol
Does that work in the main light modes as well?
Yes, what I call "Mode set operation" works the same way.
NarsilM V1.0,Ramping TEST
Chinese:
How do I need to modify the channel.h to get FET+1 on the Triple channel board
so that indicator LED is on Pin 7 and the FET on Pin 3
just the 7135*8 pin unused
I could do it electrically, but I dont understand the code in that file
Well, combo of Setups.h, RegisterSettings.h., and maybe Channels.h.
I'd set OUT_CHANNEL to 2, then edit up the RegisterSetting.h to match up signals to pins. Not sure how further to go, that might be enough, but I'd have to carefully review the ATMEL specs to be sure that all works out. Might have to do some mods to functions in Channels.h.
Certainly ramping and mode sets should work out as-is with the OUT_CHANNEL of 2 setting.
Ooops, probably definite you have to change the initialization code right in the beginning of main(). Critical initialization of ports for I/O and PWM's is there.
I dont understand how to do that
Ok, find this code in main:
  #if OUT_CHANNELS == 3    // Triple Channel
   // Second PWM counter is ... weird (straight from bistro-tripledown.c)
   TCCR1 = _BV (CS10);
   GTCCR = _BV (COM1B1) | _BV (PWM1B);
   OCR1C = 255;  // Set ceiling value to maximum
  #endif
Comment out the #if and #endif, so the code is executed. That looks like the only change you need to make in main(). This enables PWM on pin #3 I believe, which you need.
A quick question about the protection circuits.
At low voltage I believe it blinks 3 times then reduces output. In ramping, can you press the button to return to the previous level or will it just turn off?
What happens when thermal protection activates? Any blinks or just a reduction in output? Can a single button press bump it back up or will it just turn off?
My batteries were low and it blinked 3 times then reduced power. I clicked the button once and it went back up in power. I tried to video it, but I never could get it to repeat what it did earlier. It just turned off. So I’m confused.
As I know:
Low Voltage Protection (LVP) Output decreasing from 3.0V on.
Main LED: 3x blinks as indication
Indicator LED: every 8 sec
Shut off at 2.8 V
Main LED: 8x blinks as indication and shut off
You should at least remove the cells to prevent any more drainage! Otherwise your batteries can be damaged.
Taken from the Cheat Sheet for NarsilM v1.0 / BLF Q8
At thermal it should only step back without blinkies
Yes, when the LVP warning level has been reached, it will blink 3 times at moderate speed, and output is reduced. If the critical level for LVP is reached when the output can't be reduced any longer, it will blink 8 times quickly and shut off the light, and then continue to run for 6 minutes, blinking the switch LED twice every 8 seconds.
In ramping, the output is reduced by 20% of the ramping level each time.
In mode set operation, it's reduced by 1 mode.
So for ramping, if it's at the max level of 150:
  • first drop would be to level 120
  • 2nd drop to level 96
  • 3rd drop to level 76
  • 4th drop to level 60
  • 5th drop to level 48
  • 6th drop to level 38
  • 7th drop to level 30
  • 8th drop to level 24
  • 9th drop to level 19
  • 10th drop to level 15
  • 11th drop to level 12
  • for the 12th drop when it gets below 10, it's dropped to level 1
So in ramping or modes sets, if it reaches the lowest output (level 1 or mode #1), then it monitors the battery for dropping below the critical level.
I don't see anything in the firmware that would allow you to return to the previous output level by a single click. Maybe this was discussed at some point but it's not how it ever worked in Narsil or NarsilM.
I do see a problem though with having to go thru 12 steps at a minimum of ~ 5 seconds each. Here's a breakdown of using other percentage drops:
25%: 150 -> 112 -> 84 -> 63 -> 47 -> 35 -> 26 -> 19 -> 14 -> 10.5 -> 1 (10 drops)
30%: 150 -> 105 -> 73 -> 51 -> 35 -> 24 -> 16 -> 11 -> 1 (8 drops)
32%: 150 -> 102 -> 69 -> 46 -> 31 -> 21 -> 14 -> 1 (7 drops)
35%: 150 -> 97 -> 63 -> 40 -> 26 -> 16 -> 10 -> 1 (7 drops)
36%: 150 -> 96 -> 61 -> 39 -> 24 -> 15 -> 1 (6 drops)
For the next version of NarsilM, I'd feel better going with 6 drops from max, using 36%.
Okay, so it was definitely the LVP kicking in. Maybe I pressed the button just a tiny bit too long and it got brighter. Maybe I just thought it got brighter. My NarsilM driver is acting a bit funky in other ways, so it might have been a fluke. IDK, I can’t repeat it.
Thanks for the clarification.
What? double blink every 8sec?
So I should change
to
Edit: or blinks the main LED?
You could. I'm incorporating all the LVP details into a "Advanced Notes and Usage" manual. Working on it now. Basically I want something available in greater detail, we can refer people to when they have some in depth tech questions.
Tom, is it okay to dump a problem here?
I’ve got a TA FET driver built by Lexel with NarsilM that has some problems only in the mode sets area and Lexel thinks it might be in the programming. This is a 2S driver.
Dang, lost my typed response...
There's no 2X, 3X, 4X fast clicks in mode set operation. It's described in the manual, in the OP link. Fast clicks would cause countless # of inadvertent actions in mode set operation -- the two methods don't get along.
Mode memory in mode set operations is "Not Recommended". I used to say that explicitly in the manual. I should have taken out that feature, really. It doesn't work well.
What you are seeing, I think, is the lock-in time. You must be in a mode a min length of time in order for it to be saved. If you don't hold in a mode long enough, it won't be remembered.
Hi Tom,
I'm about to try to stuff a filed down TA board into an olight S15. It fits but only single sided. So with the 3 channel TA board running as a 2 channel FET+1 will the 3channel setup.h work or do I need to eliminate the bank 7135s?
Could I just reassign the pwm pins in the 2channel setup to work with the TA layout?
Way back I asked TA if he could change the 3 channel mapping to I/O pins to match up to a 2 standard channel FET+1, but it didn't happen. If he would have put the FET on pin #6 and the 7135 bank on pin #3, it would have been no problem.
So for what you got, pin #5 is the single 7135, pin #3 is the FET, I believe... I think this is the same thing Lexel asked just up above?
Even in my small OTF M3 16340 light, I was able to use a TA 15 mm board, using 3 7135's in the bank, but kept the original driver as a contact board, and mounted a filed down TA 15 mm slanted, at a angle.
I haven't tried doing what you are asking, and it's certainly possible with a little tweaking. It would be much easier now in NarsilM, since NarsilM has much more flexibility from the prior Narsil versions. I don't think Lexel knows code/programming enough to make and test the changes, though he knows a lot about the MCU and hardware designs, etc. I didn't hear back from him bout what I posted above, so I guess it didn't work out.
Boy, I could get this working, and I'm sure it will help out more than just you, and I can even find usage for it, I'm sure. Problem is time, with so much going on right now with the Q8 and GT projects, plus other stuff on very limited time availability.
How about if my next weekend, I can get to this, maybe have a tested solution. Do you have the capability to re-program the board, download a HEX file?
Hey Tom I just realized I never checked back in after this bit of advice. Just wanted to say that changing R1/R2 to these values (or very close, my set didn’t have exact matches) seems to have fixed mine right up. Works great now. Thanks again for all your help.
