Found this but it’s only 2.8 amps, anyone make a one mode driver putting out 3.5 to 4 amps? Driver size as in diameter size is unimportant.
Input needs to be one lithium ion, 4.2 volts.
You can stack the 7135 to increase power, better have a VERY good single 18650 Li Ion, 5 amps continuous will stress the heck out of anything but good batteries
Don't see any 3.5-5
These run at 3000
4000
Thanks but not 5 amps, 3.5 to 4 amps. Know about stacking drivers but I suck at soldering.
Find someone who doesn’t suck at soldering ![]()
Use stock driver as contact board and make it into direct drive. Use crappy thin wires and bad spring to limit the current going to the LED.
Here's what I would do: Take a normal 105C driver, add 3 7135s (should get you to around 3.6-3.7A). To make it a single mode you have a couple of options: 1. Remove the MCU and just short VCC to PB1 (this is what has been done in the IOS single mode driver you linked to.) 2. Program the MCU for a single mode, this way you can keep low voltage monitoring if needed/wanted.
Go with RMM ![]()
http://www.mtnelectronics.com/opencart/index.php?route=product/product&path=67&product_id=52
If you don’t need the low voltage monitoring and space not an issue you can also just slave the output of 2 single mode drivers. A 1A and a 2.8A but adding 2-3 chips to 2.8-3A driver is smaller.
