Got stuck when trying to replace the battery for a bicycle flashlight.
Can anyone tell me how to disassemble the flashlight or reconnect the battery without disassemble it?
Any advice is appreciated.
Regards,
Sam
Regards,
Sam
Looks like the top comes off from those screws in the plastic guides at each corner.
How did you take the battery out
Apologize for the confusion. Bottom cover is fixed with 4 screws, already removed, not included in the pic.
I thought the battery was attach to a spring battery contact, was stunned after I force to pull out the battery.
It seems the logic board has another 4 screws from the topside attached to the main body.
I tried to use pry tool to remove the front glass of the flashlight first, it’s pretty tight and I don’t wanna break it if I have another option.
I think remove the front glass is first and essential step to tear down the flashlight, any thoughts?
Looks like you need to loosen the 4 screws circled to remove the front.
