Honestly any quality 18650 will be fine. You will notice the massive drop in output before you over discharge the li ion. Anybody who runs their protected cells to cut off is already doing it wrong. With an in protected once high stops being much brighter than medium, time to charge.
Protection is only a back up. It isn’t a magical fix to make the battery never explode. All it does is protect the battery from chargers that over charge, users who never re charge their batteries, and shorts. I prefer unprotected because the protection circuit hurts battery performance.
But let’s all agree to not quit something, throw away something useful, just because one has to think about what they’re doing when using it, please?
Gasoline can turn a Buddhist Monk into a raging political firestorm, but it can also take him to a Baskin Robbins for the treat of his life!
Wait until you see what high-purity Hydrogen Peroxide can do (especially with a taste of one of the “anes” like Butane mixed in) in the drive chamber of an electric turbine… IFF we can just get people to quit believing they’re afraid of H2O2… (and to pay attention while using it)
Chloe, ive observed in the little time ive been here, that you are more than qualified to handle 18650 cells, you will be fine
A little caution goes a long way when charging any battery, but consider the average household that leave batteries in chargers for days unattended?
Camera batteries, mostly Li-Ion
Power tool batteries, NI-Cd, NiMh , Li-Ion
Cell phones, Li-Ion
Tablets,Li-Ion
Laptops, Li-Ion- people charge the hell out of these things especially when the battery is long gone, the dinky protection inside must kick in continuously.
AA Nimh cells left in dumb chargers for days (friends of mine do this)
Ok most Li-Ion are under the battery pack protection , but nothing will help you if the unlikely event occurs of a venting or thermal runaway, I’ve been charging batteries since 1975 in the old days of Ni-Cd without problems in home made chargers.
In fact Ni-Cd are known for thermal runaways, and are installed in budget power tools with no protection whatsoever (I have one and have opened it to see if I can mod to Li-Ion)
I recently modded / repaired a Li-Ion power tool pack, only one thermal sensor inside under a single cell out of 5 (18V pack), and 2 cells were at 0V, the others all at 4V when I tested them, and this power pack was sitting in a charger for days.
I have dozens of unprotected Li-Ion harvested from laptops, all tested and the duds recycled away, I use the good ones for all my single 18650 lights.
I don’t however charge unattended any battery whether its an eneloop or Li-Ion, lead acid , any decent charger can fail.
This. Having actually done many run time tests on lights where I leave them on and just let them go, most lights have a way of telling you it’s time to charge them. They get really dim. Constant output drivers are found on nicer lights anyway. And the thing is they get noticeable dim for quite some time before they ever reach 2.7-2.8ish. I run some laptop pulls in a convoy s6 and since the light isn’t used a whole lot, I charge it once every two or three months. It’s never anywhere near 3.7 volts. Most lights begin to dim after 3.7 volts…. so you have an entire volt of dim light that acts as an idiot warning. That volt is actually quite a long time of noticeably dim output.
+1 for Dimbo, but I must point out that there are a lot of people on this forum who won’t notice the difference between High and Medium (the first “needs charging” indicator) because they never use High or Medium!
However, comma, I have recycled more bad laptop 18650s than what good ones I have for use now, and those reached ~0VDC without any “undervoltage” incidents. In fact, the only way I have to find them is the VOM, or stick them in a flashlight. It’s strange watching one “self-discharge” from ~4v to ~0v in your hand. So much for that end of the spectrum.
No overvoltage capability, with the single- and double- chargers I got “for free” (replacement cost for both ~3 bucks), I tested them for many recharges outside on the porch. I finally quit leaving a “ready spare” on the charger because between whatever’s in the light when I pick it up, plus the “pocket spare” 18650 I carry with me, plus the few recently-charged ones lying about, I just got tired of looking at the green LED.
I would honestly like to see the “worst-case scenario” with an 18650. I have actually blown up a 12VDC SLA car battery at about solar-plexus level, which scattered parts across Main St. Columbia, SC and sent me inside to wash the electrolyte off my face & I had to throw away the “business-casual” shirt and tie I was wearing. Do as I say, not as I do! But the event was only annoying, not actually dangerous, except for the scary face splash. Obviously I blinked quickly enough (plus sunglasses) that none got in my eyes!!
I’m not doubting that the Lithium chemistry is scary and exciting, but I suspect a little bit of “believing” in the horror stories…
So my side project for now is to rig a way to make a dead short across a fresh-charged 18650 (NOT at solar-plexus level!!) so I can “know” what to expect.
I’ll use my smallest SD card for the video. If it fills up before anything bad happens, “I’m calling this myth ‘busted’”… Sorry…
(There’s a method to this madness, you know…
Where I work sometimes, Safety is more important than profitability or productivity. “Intrinsically Safe” means there’s nothing in the item which could cause a fire, regardless. They’re stuck with 2*AA Streamlights now, and my “pocket spare” 18650 gets some nasty looks. (Yes, some of those “pocket spares” came from “dead” laptop packs from that same plant…) A 4v spark would condemn the Lithiums to the parking lot. If the first test isn’t too embarrassing, I’ll try one in a stoichiometric mix of Propane and air… This could be fun… BRB…)
That venting was with a primary lithium cell CR123, which according to the “Gods” at the other forum are more dangerous
See excerpt from greenbatteries.com
“There are several important differences. The practical difference between Lithium batteries and Lithium-ion (Li-ion) batteries is that most Lithium batteries are not rechargeable but Li-ion batteries are rechargeable. From a chemical standpoint Lithium batteries use lithium in its pure metallic form. Li-ion batteries use lithium compounds which are much more stable than the elemental lithium used in lithium batteries. A lithium battery should never be recharged while lithium-ion batteries are designed to be recharged hundreds of times”
First of all, I think you are fully qualified to use Li-ions. Remember to respect them, but don't be too afraid.
Especially after scaru's incident, I'm not confident with any light not accidentally turning on.
Luckily the S5 has anodized threads and it can be locked out by opening the tailcap about 1/3 turn. That's what I'm always doing with mine when putting it to backpack (or similar).
FWIW, I use unprotected flat top NCR18650B in my S5. Fits well & offers good capacity.
Over voltage protection is provided by the charger and under voltage protection by S5 driver. Possible dangerous event would be the light shorting during use, but then the user can notice & act on that. (If the light turns off for any reason, open the tail cap and remove cell.)
Wow, really? I did find a couple of explosion threads featuring that cell but who knows if they were mixing cells of different brands etc.
There was this thread where a cell exploded whilst inside a light and injured the poor owner. 3x18650 but he didn’t measure the cells before using them. :~
I remember reading all these disastery threads before I joined BLF and they can put you off especially as I didn’t really know. Even now after rereading them, I am wondering if I should really leave a cell inside a light I use often. “What if it vents?” “Will the light explode?”
I didn’t get any AW yet. I thought they were out of stock but I noticed two AW 2000mAh is 26 USD shipped, compared to 14.79 USD for a pair of Panasonic 3400mAh.
Also, 2000mAh doesn’t sound too low but I was also planning on using the ML-102 with a cell to top up my phone. I’m not really sure how much it needs to be.
Vapors aren’t the real problem in a chemical factory (being more of a “normal course of business” kind of deal), but that’s darned interesting.
It’s amazing what you can observe, just by looking!
Not tending to trust blogs and chatroom posts (present company EXcluded, of course!), I went and found something only mildly interesting if directly relevant:
You’ll notice there’s no HF, and there are those unlabelled peaks… Not sure what to make of this, especially with his 80C temperature limit, but it is directly relevant.
But let’s look at the CPF story itself. When I was maybe 10, we found a discarded gallon bottle of H2SO4. Yes, I sniffed it. Do NOT try this at home!! But, it seems to have somehow enhanced my sense of smell. All ends well in Dimbo’s weird world! So this story pushes a couple of my buttons. But wait…
HF, sniffed or even touched, is exactly as bad as the writer implies!!! His claim of “last night” isn’t plausible, given the rest of the story, but a cautionary tale isn’t told in court. So don’t let me diminish his advice. Think! Pay Attention! Be Very Careful With Chemicals! Even DiHydrogen Monoxide will kill you quicker than keep you alive!
But WAIT…
For DECADES now, in “the land of the Free, the home of the Brave”, “we the People” have allowed anonymous agents of our government to add Flouride to our water supply. You can say that softer, less scary, but it’s no less a fact.
If you track down the HF lead, guess what the MSDS says? No, really you must guess or I will pout!!
Keep your sense of humor…
Here’s some Truth, to still Laughter in you forever:
If you’re not going to read the whole thing, before you drink public water again, at least read the last page:
Ask your nearest bureaucrat, how do they put Sodium Fluoride (NaF) in the water they make you pay to drink? They’ll bury you in BS, but you can beat them back with the Material Safety Data Sheet for Sodium Fluoride . Especially this section:
Yeah. You’re right. This doesn’t have a dad-gum thing to do with outgassing or any other Safety issue of 18650s.
But it could help explain the True Believers’ discomfort with Facts, Logic and Truth… “May affect behavior”…
At least it should bring some perspective to the CPF story…
Speaking WITH you all, of course, not ABOUT any of you!!!
Dim
(And no, I haven’t ginned up a dead-short test rig yet! All this put a bee in my bonnet about finding a willing chemist with a GCMS to test the result.)
AW tends to charge a lot. You can get the same quality, often the same exact cell elsewhere for less.
Efest IMR 18650 2000mah outperforms AW IMR 2000mah on HKJ’s charts.
Panasonic CGR18650CH are kind of in between Li-mn / li-ion & are suppose to be good too… If the FT forum report of one venting hasn’t turned you off them. :face_with_monocle:
