Hey all! I’m hoping you can help me out. This is my first time building a light and I can’t figure this out.
I was thinking of using the Lume1 FW3X mcpcb w/rgb aux lights and FFL350RD 3500k emitters. What 17mm driver should go along with this? I’d prefer something that can run Anduril 2. But it’s not a requirement. However, something that will utilize the rgb aux is a requirement.
If that’s not doable, what’s a better suggestion for 3 of those emitters?
You can’t run Anduril on a S2+. The S2+ uses a mechanical switch and Anduril requires an e-switch.
Also you cannot run Aux on a mechanical switch light.
You could use secondaries with a Dragon Driver(Link) but it would be single color not RGB.
If you want Aux and/or Anduril you’ll need a host with and e-switch and a driver that fits it and has RGB Aux capabilities.
Also if you still plan to use the FW3 MCPCB and Aux pcb it will also have to be compatible with a 20mm triple configuration.
I don’t know of any stock hosts that are setup for this.
Some Maeerxu flashlights use drivers with rear mechanical on/off switches and fancy aux light functions. (But no aux lights on when the flashlight is turned off.) The UI is quite complex. other Archives - maeerxu
I haven’t measured the pill/ driver size in mine, but it’s bigger than an S2+ AFAIK.
If you plan to use an illuminated tailcap you’ll need to add a bleeder resistor to the driver.
The Dragon Driver has the pads for one.
I recommend a 470-475Ohm Resistor.
