I’m sure someone much more knowledgeable than I am will chime in… But since I was in your situation a very short time ago, and now I’m programming attinys and building boards from oshpark projects graciously made public by some of the awesome members of this forum… I figure I ought to give back a little.
Check out the flashlight wiki here .
Assuming you have a host that takes P60 dropins (I’m kinda partial to Solarforce, myself), and have a bare P60 dropin in front of you, you really only need a few things. Apart from a soldering iron and solder, you’ll need some sort of thermally conductive paste (or epoxy) - and then you need two main components…
1. A driver (a small microprocessor-controlled PCB board to determine the user-interface (UI) of the light, and 2. an LED mounted on an MCPCB (circuit board). The driver will need to be 17mm in diameter and the LED’s MCPCB will need to be 16mm in diameter. The current depends on your choice of driver.
I also recommend you get solder flux and a spacer to help center the LED.
Considering that you’re in TX, if you want to make things easy on yourself to start off with, ignore all China-based websites and go to mtnelectronics.com . There’s lots of great stuff for sale on many other sites, but if you’re trying to learn, most of them will confuse that process as they’re utterly riddled with incorrect information. I say this as I’ve got like 4-5 orders somewhere between China and my house. They have great stuff. They also have a ton of garbage for sale that doesn’t make any sense, and it’ll take a bit for you to be able to know the difference. MTN is safe, as is illumn.com (another good US seller)… But mtnelectronics is singularly-focused on flashlights and flashlight components. Stick to that for now. The proprietor, RMM on this forum, is from all accounts a great guy and I’ve spent way too much money on his store with zero regrets.
You said you wanted an output of 2.0A - the easiest and most simple way to accomplish this is to get you one of these and have RMM remove two 7135’s for you (an option selectable on the store). That’ll get you to roughly 2.2-2.3A, but some will be lost in the host due to inefficiency in the driver and current restrictions in the host (springs especially), so you’ll be pretty close to your desired 2.0A.
You’ll need an LED mounted on an MCPCB, which MTN also sells. Since you said you’re looking for around 700 lumens, your only option is an XM-L2 U2 or XP-L V5 at that current to get close to the 700 lumen number. An LED with a smaller sized phosphate die will throw light farther (XP-G, XP-G2, XR-E, etc), but will not have the output you’re looking for.
The driver will come with LED leads which will correspond to the + (red wire) and - (black or white or blue wire depending on driver. Once you’ve got all the parts and pieces, it goes together fairly simply - driver in the driver cavity, drop of thermal paste under the LED mcpcb, wires through the holes in the pill. Solder the wire from + on the driver to + on the LED board (usually red), likewise with the - wire (usually not red).
Hardest part in assembly is soldering the ground ring on the driver (spring side facing battery, wires toward LED, in case that wasn’t obvious) to the brass pill. This is where you’ll be glad you’ve got the solder flux as I’ve found it to be darn near impossible without it. Put flux on the ground ring and on the pill, bridge the two with solder to lock the driver in place and provide an electrical path to go from the ground ring through the host to the tailcap to the negative side of the battery via the switch.
Screw the reflector on (trying to get the LED as close to centered as possible - spacers help with this), put the huge spring on the exposed threads on the pill’s battery side, and that’s about it.
Hope that helps. Feel free to ask whatever questions you may have. This forum has been an irreplaceable reference to me, for which I am very grateful to the other members - and there’s a ton of great info and great people on here. Good luck.
