i am usinng a 5x Cree XML bike light with the driver mentioned in post #24. I want to have a higher current from the driver. Do I only have to remove the 250mOhm resistors and replace them by 100mOhm to get around 2A output?
Ok, i will measure the current today. The voltage at each LED was around 2,7V, so I believe that the current is arround 700mA?! Is it better to use a bigger choke?
So I can solder the R100 on top of the R250? Is this still parallel? Is it 0805 or 0603?
If this dont work, i could take the driver from dx.com? Is it fitting for my 5x Cree XML setup?
Thx!!!
@ledoman: u are using another driver in your link.
I have measured the current. It is 0.485A. This is lower, than I thought. Why would the manufacturer do that? Thats really low current.
Would you explain where exactly did you measure the current, have you had short and thick enough multimeter wires, what is the input voltage and the current, are leds connected in series or paralell, ….? In short explain all the details.
Ok, still we don’t know what is input current. I’m guessing what if 2S2P battery pack has some current limitation or the cells are unable to deliver sufficient power. Can you tell more about battery pack, what cells are in it? Is it cheap chinese one or some good staff like Sanyo or Panasonic?
So this is a boost driver. I haven't worked on those. Comfychair may have some input on this. I only know that boost drivers have are pretty limited by nature on the amount of current they can flow.
If no one can help you, you may want to consider going to a Buck driver and wiring your emitters in parallel.
if have to test it, if it is brighter without multimeter.
Should I add a parallel resistor to the actual driver? Why is there such a low current?
I found a review: SkyRay 7T6 review | Mountain Bike Reviews Forum, where somebody runs a similar setup. the driver looks also similiar and the reviewer gets 3A out of it. but i dont know how.
I have found one broken resistor. it was one of the two 250mOhm. I replaced it with two 120mOhm Resistors. The measured current was at 1.5A, but i do not really understand why.
That is a good thing though. You got if from .485 to 1.5. Nice work.
This happens a lot. The math says you dropped resistance down to .048 ohms and should get 4.1 amps of current. Most likely, some other component is limiting the current now. I imagine you could short that resistor bank and not get much more current.
5 emitters at 1.5 amps should be a respectable amount of light. The xml is pretty efficient at the current too.
Pinkman, last time you have powered light with 7.7V packet. What if you power it with fully charged 8.4V packet? I’m wondering if there is not enough voltage to run leds at higher current. What are specifications for this driver, can it be powered with higher voltage than 8.4V?
