#include <avr/sleep.h>
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV (bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV (bit))
#endif
//**here you set brightness of modes
int mode1 = 255;
int mode2 = 8;
const int buttonPin = 1; //setting button pin
const int ledPin = 0; // setting LED pin
int buttonPushCounter1 = 1; // counts the button pushes
int buttonState1 = 1; // tracks the button state
int lastButtonState1 = 0; // last state of the button
int buttonState = 0; // Button status
int lastButtonState = LOW; //Button set to LOW
long lastDebounceTime = 0; // Debounce status
long debounceDelay = 50; // Debounce timer
void setup() {
pinMode(ledPin, OUTPUT); // Sets LED as output
pinMode(buttonPin, INPUT); // Sets button as input
sbi(GIMSK,PCIE); // Turn on Pin Change interrupt
sbi(PCMSK,PCINT1); // Which pins are affected by the interrupt
//mode one: LED is set to 100% brightness by default
int modeone() {
analogWrite(ledPin,mode1);
//mode two: LED is set to your preference of brightness (my default is about 30% = 76)
int modetwo() {
analogWrite(ledPin,mode2);
//mode three: strobe light, I set it to be the most disorienting in darkness but feel free to change on and off times (in [ms])
int modethree() {
digitalWrite(ledPin,HIGH);
delay(15);
digitalWrite(ledPin,LOW);
delay(100);
//Sleep mode
int modefour() {
analogWrite(ledPin,8);
delay(20);
analogWrite(ledPin,0);
delay(20);
delay(20);
delay(20);
delay(20);
system_sleep();
void loop() {
// All the debound button press stuff
int reading = digitalRead(buttonPin);
buttonState1 = digitalRead(buttonPin);
if (reading != lastButtonState) {
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != buttonState) {
buttonState = reading;
if (buttonState1 != lastButtonState1) {
if (buttonState1 == HIGH) {
buttonPushCounter1;
if (buttonPushCounter1 == 5) {
buttonPushCounter1 = 1;}
else {
lastButtonState1 = buttonState1;
lastButtonState = reading;
//switching modes:
if (buttonPushCounter1 1) {
modeone();
if (buttonPushCounter1 2) {
modetwo();
if (buttonPushCounter1 3) {
modethree();
if (buttonPushCounter1 4) {
modefour();
//loop end
void system_sleep() {
cbi(ADCSRA,ADEN); // Switch Analog to Digital converter OFF
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Set sleep mode
sleep_mode(); // System sleeps here
sbi(ADCSRA,ADEN); // Switch Analog to Digital converter ON
ISR (PCINT0_vect) {
