Hello, our new product RK6006 4 digit power supply is coming. Hope you like it and you can check the product information and make order in the link below or at the end of this article:
https://www.aliexpress.us/item/1005005429587089.html
As what we do all the time, we will set the lowest price when new product is released, so here is the price:
RK6006:$26.99USD (normal price:$36.99USD )
RK6006-BT(has Bluetooth function to APP):$29.99USD (normal price:$39.99USD ) Discount Time: 2023.4.23-2023.4.27 PT(5 Days) .
for now the promotion already ends, it is back to normal price
You can treat it as super updated version of DPS5005-USB , and most important thing is that the discount price now is lower than DPS5005-USB! compared with DPS5005-USB, it has higher output range(60V6A) than DPS5005-USB(50V5A), more accurate output, bigger screen, more customs display, and it supports firmware update, if there is new functions, you can update the firmware with PC software, you can check the product page to see more functions.
Here are some important features about RK6006:
·Support 60V 6A max output
·Low ripple: 100mV VPP output ripple typical
·Custom display color and display style
·1.54 inch HD display
·PC software/APP control(K6006-BT only)/support firmware update/multiple protections If you have any questions about RK6006, you can contact us in the way below:
Contact us on Aliexpress directly
Contact my email:1749808860@qq.com or WhatsApp: +8615868147353 or WeChat: 15868147353
Technical parameter
Model: RK6006/RK6006-BT
Input voltage range: 12-68.00V
Output voltage range: 0-60.00V
Output current range: 0-6.000A
Output power range: 0-360W
Output voltage setting measurement resolution: 0.01V
Output current setting measurement resolution: 0.001A
Output voltage accuracy: ±(0.3%+3 digits)
Output current accuracy: ±(0.5%+5 digits)
Output ripple typical:100mV VPP
Working temperature range: -10℃~40℃ Buck working mode: (input voltage÷1.1)-1
Over temperature protection: System temperature>80℃
Screen brightness setting: 0-5(6 level in total)
Screen: 1.54 inch 240240 color HD display Weight(with package):About 0.15kg
Product dimension: 7943*54mm
compared with DPS5005-USB, RK6006 has bigger screen, silicone button which is not easy to be broken, and it has higher output range, in the mean time the output accuracy is better too, and the most important thing is that the discount price of RK6006 is lower than DPS5005-USB, if you need DPS5005-USB recently, you can choose RK6006 now
RK6006 also has PC software and APP, for mobile phone connection, only RK6006-BT supported, and compared with RD series wifi connection, Bluetooth connection is quite simple https://www.aliexpress.us/item/3256805243272337.html
RK6006 feedback
stable output, and small sized, it is compact design and compared with a 18650 battery, it does not look big, good, waiting for a suitable power supply for it https://www.aliexpress.com/item/1005005429587089.html
RK6006-BT android APP crash problem
hello, if you are using the android “RUIDENG” APP and it crashes, it should be language problem, you can contact us and get the way to solve it, and we will upload a new version to solve the problem, sorry for the inconvenience caused to you
for now we have update the “RUIDENG” app to solve the frash and crash problem, it has not been approved in app store, but you can download it in this link: http://www.ruidengkeji.com/apk/Ruideng_V1.0.15.apk
