Hi guys,
today I review the brand new Archon S24V, first look!!
This is a video light which I find very convenient, small sized with only one 26650, and an output of 2400 lumens! But still providing an extremelly long runtime of over 4 hours, take a look at the runtime test!
Then we have the Ball joint! very nice accessorie together with all the included components and the package itself.
The light has an integrated over-discharge protection for the battery! This means you can use unprotected cells and not worry about over discharging them. This is a great feature not found in many lights!
The switch is the usual Archon magnetic Push switch, I find it very convenient to opperate as it switches quite easilly, but still hard enough to prevent accidental switching.
It is powered by 4pcs Cree xm-l leds with a max output of 2400lumens cold/neutral-white light, and 2 xp-e red leds, with an output of 200 lumens red light.
See the underwater opperation here!
It has a 2 O-ring design, the O-rings are very thick and came well lubricated!
The thread is short and clean cut.
Both negative and positive contacts use a spring for ideal contact.
The battery included is a 4000mAh 26650 protected li-ion battery, the charger has a 1A output and was a EU plug in my case.
Included in the set is the light, ball joint, battery, charger, a wrist strap, spare-O-rings and an english user-manual.
See the review, unboxing and underwater video here:
And see the Runtime test here:
Thanks for reading this!
Greetings
Mark
