New Arrival: RK8009 – Compact Design 80V 9A High Current Power Supply Officially Launches!
Hi everyone, our new products RK8009 power supply is officially launched!
Limited-time discount + limited stock — don’t miss out!
Promo Price (Limited Time)
RK8009:$30.99USD (normal price from:$40.99USD)
RK8009-BT:$33.99USD (normal price:$43.99USD)
Discount Time: 2026.9.2-2026.9.8 PT.
Stock: Only 100 units at this price. Once sold out, back to normal price!
Buy Links
RK8009: [u]404 page
RK8009 New Features compared with RK6006
1. Higher current range
Supports 80V 9A output range, while RK6006 is 60V 6A max current
2. Input Under-Voltage Protection
Protects battery input from over-discharge, effectively extending battery life.
3. Timed Output Shutdown
Custom working duration available. Output auto shuts off once the countdown ends.
4. Output Short-Circuit Protection
Instantly cuts off output when short circuit occurs, with SVP Warning displayed
5. Type-C Communication socket
Updated to USB-C connection to PC software control compared with RK6006 Micro-USB port;
Limited stock & lowest launch price! Don’t miss your chance to get the new RK8009!
Hi, in this video we show the short circuit protection of RK8009, if you disable it, when short the output + -, it will be CC mode, And if you enable it, when you shot the output + -, It will beep three times and turn off the output and show SCP
Hi, in this video we show how to quick set the output voltage and current, together with the OVP and OCP valuje setting
