【New Arrival--Sofirn SR20mini: white+red led Mini Compact EDC Flashlight】
Hi BLFers,
Following the release of our SR12 flashlight designed for long-distance lighting, we are now releasing a new member of the SR series - the SR20 mini, a flashlight more suited for everyday home use. The SR20 mini, with its more compact design and versatile light sources, meets all your lighting needs from outdoor activities to emergency home lighting.
Specification
Emitter : 3 x CSP2323 white led(6000k, 90+CRI) , 3 x HFL1-R red led
Driver: buck driver for red light
Max Lighting Distance: 142m
Output: 1200 LM
Battery: 1×18350
Charging Connector Type: USB Type C
Water Resistance: IPX8 waterproof
Mounting Type: Magnetic Mount
Cap Shape: Crenulated Bezel
Weight: 35g(without battery)
If you want to participate in the review of SR20mini, please enter in our lucky draw.
:boom:Giveaways: 3 * SR20mini
:boom:The entry rule: Leave the comments in this post
:boom:Deadline: December 15
6 Thanks
I love the form factor! I’m a big fan of the IF19, and I was secretly hoping for an upgrade of it with efficient driver and a little warmer LED. This one is more of a flooder, as stated. I wonder why the regulation is to apply to the red led only? Perhaps a typo? There is also one more possible issue by the look of it: the lanyard hole may interfere with tail-standing.
Looking good, specially the USB-C port, the red LEDs (which I assume can be controlled independently) and the buck driver (but “for red light”? perhaps you meant “not for the red light”?).
OTOH, the LEDs don’t look good: perhaps it’s the camera settings or something, but I see too much green on that beamshot pic :-/
Also, I see no mention of the UI. Anduril, please? Pretty please? :slight_smile:
I like the small form factor.
I hope the tint is not that green though and it is just the camera setting.
But I’m quite interested in it, especially it has red led.
Hmm, looks like tint shift, maybe they used a different type of CSPs? Hopefully they are not low CRI.
Well, that’s a flashlight that will make a nice EDC. Small, but quite potent. However, personally I’m not the greatest fan of internal charging. But if it can’t be avoided, I prefer a magnetic coupling like the Skilhunt M150
I would love the opportunity to evaluate this light and give my feedback.
I’m In for the giveaway.
Is there any reason only the red light is buck-driven?
Also are the flood emitters high CRI?
Using a buck driver only for the red channel but not for the white one is a little weird. Can’t you share the same driver circuit for multiple outputs? I would have expected the white one to be regulated.
It seems nice, maybe it will beat the SC13?
I like this form factor!
I hope that main led channel driver isn’t fet type.
That looks like a fun light.
Nice looks :+1::+1:
CSP2323 - nice to see high CRI LEDs, I hope You will make 4000K version available.
FET driven main LEDs… God why :pensive: Maybe it is was FET+3x7135, but I assume it’s FET+1x7135 - so regulation will be bad…
UI - I would prefer Anduril 2, but at least it’s close enough in basic use
I’m glad You went with 18350, not 16340
Certainly looks interesting.
Beam tint looks great(w weerapat_k’s shots)
Looks green here. Or is it both?
Agree w lower cct request.
Regulation seems strange.
As to UI, jury’s out, but would prefer anduril.
What CCT?
Really looking forward to this one … :flashlight:
I thought I entered this giveaway, but I dont see my comment, so here is my entry comment. Thanks Sofirn!
waiting for my paycheck to get if22a, maybe this is a sign to get a flooder
Thanks for your reply and sopport. Here is SR20mini UI.
CCT of SR20mini is 6000K.
