Must be in stock then. Probably the best time to order one but I will hold on till there's a review.
If this is waterproof, it can even be a great bike light solution. Finally an AA flashlight in compact form that may possibly have a long runtime (on low/medium). That's why I am particularly interested in the current draw in low/medium modes. Till now I have been riding with a single AA flashlight but it goes out around the 90 min mark, not ideal at all.
I bought both of them because I’m always looking for NiMH lights to give to friends/family,
won’t trust any of them to handle Li properly…
A note:
The fit with some AAs is tight (or even impossible)
I had bought a lot of the 2200mAh LSD AAs from HobbyKing
What I got were EMB brand cells (they’re good, I measured capacities)
The diameter of those is ~14.5mm. They don’t fit into the battery tube when assembled into the battery holder.
You can force them in, but the cell ‘wrap’ will scrape off.
The Tenergy & Sony cells I have are ~14.2mm, and they’re a tight fit.
You can slide them in with some care.
So here I’m using freshly charged Sony CycleEnergy 2000mAh AAs
Aurora SH-3AA:
High 2.3A
Med 0.5A
Low 0.05A
Same for the UltraFire SH-3AA
Unloaded battery ‘pack’ voltage after the measurements was 4.15V (—> 1.38V per AA)
A couple questions, for the Ultrafire version does the reflector come off like the pic on the Aurora version?
Also, how long did it take you to receive the lights after ordering them?
I have a PA40 already. I’m wondering if there is any reason to get this. It’s pretty inexpensive. I thought I read it was driven hard. Anyone have both?
With a freshly charged MarsFire 26650
High 4.3A
Med 1.1A
Low 0.08A
I can’t find any difference between the Aurora or Ultrafire both electrically or mechanically, apart from the labeling.
I ordered both from DX.com
Separate orders, so one wouldn’t hold up the other
Aurora SH-3AA — Ordered 4/26 — Shipped 5/8 — Arrived 5/19
Ultrafire SH-3AA — Ordered 4/26 — Shipped 5/2 — Arrived 5/17
Disassembled they both look like this:
(Didn’t take the switch apart further)
(Excuse the hair, pic taken on the cat tree…)
Pill bottom
Pill top. Diameter ~28mm
The star on one of them seemed tight, the other one rotated easily.
Heat transfer from pill to body should be good, but from LED star to pill might need improvement.
Reflector
Diameter ~41mm
Length (bottom to top) of reflector is ~36mm
First try at beam-shots. Realized that I don’t have a single good place in my apartment for them,
no position with a bit of distance to an empty wall…
(Manual/fixed settings, the same for all the following)
26650 High
3xAA High
26650 Med
3xAA Med
26650 Low
3xAA Low
Distance to the wall was ~ 4 feet
Diameter of the outer ‘ring’ on the wall in the beam-shots was ~ 4feet
Cool, I’ve been waiting for more info on these. Looks like the best value high output multi-aa light to me. Looks like a good birthday present for my dad or any non-flashoholic.
Thanks Sigster! I missed this update! So apparently it uses a typical C8 reflector like the Cyclone C88 does. Any comments on general build quality? How are the threads? (Typical cheap chinese threads which like to cross-thread easily?) How's the quality of the 3AA battery carrier? Good & solid? Cheap and feels like it'll crack/break easily? How's the tint? Cool blue?
Seems it's direct drive on high. Perhaps that works better with AA's than the nangj 2.8A or 3A driver? Any ideas on if this is true? Would direct drive enable it to work on alkalines better? (Not that I am suggesting alkalines for primary use.)
