1) Super Power CR-18 Led Flashlight, contains 18*CREE XML2 LED Chip. Up to 8700 Lumens (when using 6 pcs 18650 batteries). Powerful enough to light up an entire football field.
2) Bulb Quantity:18 Light, Color: cool white, LED Lifespan: 100,000 hours.
3) Mode Arrangement: High(100) / Middle(50) / Low(30) / Strobe(100) / SOS, Lighting Distance: 287 m
4) Battery Configuration: 2 or 4 or 6 x 18650 Rechargeable Batteries(not included), Input Voltage: 3.6-4.2V, 4.2Vmax
5) Runtime: 2-4 hours, Switch Type: Click/Clickie, Switch Location: Tail-cap, Lens: Convex Lens
6) Waterproofing design: IPX7 (But Can’t put it into water directly)
7) Internal wiring applies the high efficient booster circuit, working voltage is wide and can utilize the batteries in the largest extent
Color: Black
Material: Aviation grade aluminum alloy
LED:18*CREE XML2
Voltage: 8.4V
Color BIN: Cool White
Mode Memory: No
Switch Type: clicky
Switch Location: Tailcap
Lens: Toughened glass
Reflector: Aluminum Textured
Beam Range: 287m
Strap/Clip: Not included
Dimension: 8.6in × 3.5in x 2.1in
Weight: 863g
I will shoot some videos and upload them on Youtube. We have any suggestions, you can speak. Thanks
