The MX Series is now available for pre-order with shipping estimated to begin in early November. Initial supplies are expected to be limited, so if you are interested in securing a unit please send me a PM for a BLF price quotation and ordering instructions.
Kit Configurations are available with all LED Options.
Kit:
MX25L3 flashlight
Spare o-rings
User Manual
Mil-Spec Para-cord Lanyard w/ quick attachment clip
Flat tail-cap (tail-stand)
Signal connection through the body tube for rear accessories
Tailcap w/ switch and tail-standing ability
Flashlight head comes with front-mount thread for bezel and filter attachment
Stainless steel bezel
Heavy Duty Nylon Holster w/ self-retention device and open-top design
ET54 diffuser filter, ET54 yellow filter, ET54 red filter, ET54 green filter, ET54 blue filter.
I’m sort of stuck on the kit… I like the SS bezel, but not otherwise too interested in the rest of the items. That makes for a rather expensive SS bezel. Are the SS bezels available separately?
Edit: I saw a similar discussion on CPF about the SX25L3. It seems the kit accessories can’t be put on the non-kit light. I’m guessing that means the SS bezel can’t be put on a non-kit light on the MX25L3/MX25L3C also.
Yes they do make that clear, if you buy the base unit you cannot add the kit option later but that does not eliminate the possibility of offering it as after sale accessory. They may not - only producing enough to support the kit version but I will see if I can confirm it. I would think in the case of a bezel, replacements would be popular option.
They said there is nothing for the SS bezel or colored filters to thread into. Apparently the main outer bezel that hold the lens in is different. The one has threads for accessories the other doesn’t. So, even if you could buy the kit parts you can’t attach them to the light.
Thanks for the update. I guess that makes sense in why the note is there you must order the kit initially although from a production stand point I am bit surprised there would be a design difference.
