Not a budget light, using the SBT-90 led paired up with big SMO.
http://www.olightworld.com/en/index.aspx
Also it's too big.
Will be more excited on smaller lights with SBT90: SR55 UT? or Nitecore TM20
Also it's too big.
SR95
SST-90 P bin.
Bezel 90mm
Hollow out structure in the head part reduces its weight by 30% than that of traditional sealed packet design.
BTW, I want CST-90 2700 lumens, to make my CST-90 Flood to throw
Feature of SR95UT
1. Uses world-class super bright Luminus SBT-90 LED.
2. 60lm(48h)-300lm(10h)-1050lm(1h55min);
Max. 820m long throw???
So all I have to do is sell one of my kidney's to be able to afford this light?
I spilled my coffee on that one!!
Wow. Thanks for the heads-up.
For the more budget-minded, there should be a number of lightly-used SR90s coming up for sale....
1300 lumens at 9A drive current? Doesn't makes SBT-90 look very good, considering Match got that much out of (copper-bound) XM-L at 5.4A..
Wonder how my Direct Drive 25A+ PT120 green Mag 4D Aspheric would compare? I know it ain’t white.
I'm not sure where that came from. The Olight site quotes 2000 OTF.
http://www.luminus.com/products/SBT-90.html
"Max lumens: 1,400".
Also, this page says highest mode is just 1050 lumens: http://www.olightworld.com/en/products_show.aspx?ProId=1390&CateId=102
Shadowww:1300 lumens at 9A drive current? Doesn't makes SBT-90 look very good, considering Match got that much out of (copper-bound) XM-L at 5.4A..
My reply #1
SST-90 P bin = max lumens is over 2000 = Use in SR95
SBT-90 (no dome) = max lumens is about 1400 = Use in SR95UT
SBT-90 in SR95UT with no dome means wide angel but good for reflector to collect light for max throw.
I don't know if it will beat the SkyRay King in Brightness ? That cheap King can put out some serious L & L .... " LUX & LUMENS "
Used SR90 cost about $250, so only half a kidney.
De-dome SR-90 will beat the SR95-UT
De-dome SR95-UT and you’ll get a laser :Р
SR95 UT use SBT-90, there's no dome.
Now there is SR95 review @ CPF...
So now there is no need to get that 400 bucks Elektrolumens or $269 Lambda Super VPT (sold out anyway) ....
Feature of SR95UT
2. 60lm(48h)-300lm(10h)-1050lm(1h55min);Max. 820m long throw???
168100cd, sq root to get 1 lux @ target, then times 2 to get 0.25 lux @ target.
Pok:
Feature of SR95UT
Max. 820m long throw??? >>> I mean that is true LOL
