do you mean you are only running the 4LED optic, using a thick O ring in place of the protective 1mm (?) lens? Where did you get the O ring, or what are the dimensions?
Thanks, I think you’ve probably got the correct one there but in the end I’m happy with the O ring even if I cant tighten the end bezel on all the way.
Thanks. I got a 27x22x2.5 o ring from eBay. It’s like 5 bucks for a few pieces, much cheaper than 19bucks w shipping for that lens earlier in the thread.
If it’s like mine it will look like the O ring is to large but when you push it in to place it will stay nicely. You also wont be able to screw the bezel in as far as it originally was but I really dont notice the difference.
I also like the idea that there’s one less layer of material for the beam to pass through
