Features:
XHP70LED output,up to 5000hours service time
Maximum output 3200lumens
Mirco orange-peel reflector
Maximum beam distance 525meters
Powered by 2pcs of 26650 li-ion rechargeable battery
Reverse polarity protection
Memory function
Anti-slip and sweat wicking knurling
Dual switch controls brightness levels and flashing modes separately
Made from aircaft-grade aluminum
Mil-Spec Type III hard-anodized finish
Toughtened ultra clear glass lens with blue coating on both sides
Waterproof to IPX-8 standard,underwater 2meters
Package included:
1 x MAXTOCH MISSION M12 XHP70 3200LM LED Flashlight
Features:
Adopts XHP70 LED
Max output 3000lm
Max beam distance 570meters
Powered by 2pcs 18650 rechargeable battery or 4pcs CR123A
Reverse polarity protection,to protect from improper battery installation
Memory function
Anti-slide and wicking design
Reverse rear switch,three brightness
Made from solid aluminum stick
Mil-spec Type III hard-anodized finish
AR lens with blue coating
Spare tactical grip ring
IPX-8 waterproof up to 2meters
Package included:
1 x MAXTOCH SHOOTER 2X XPH70 3000LM Searching LED Flashlight
please use this form if you want to know the deal (a lot less work for me ;))
Could you post the lumens for each mode on the lights above and the run times for each. Thank you. And great new line up. I had to miss the 2x group buy last time I was in it but lost my job days before the code went active. Maybe I can request one of these for my birthday in a few months coming up
if you go to the shop (links arein the pictures) or to the manufacturer you will find that data.
Maxtoch does not tell a runtime in Turbo - maybe due to a stepdown?
could mean they are serious about runtime in the other Levels...
Okay, I’ll ask the dumb question. How does adding a 2nd 26650 and the extension tube to the Mission M12 XP-L HD only increase the battery life by 50? It should double it (ie: increase by 100). Of course the runtime data in the chart shows it shortens the life. :person_facepalming:
