【New Product】XTAR L4 Pro Smart Charger
So glad we released a new charger L4 Pro, which is a smart four-slot charger for AA/AAA NiMH and 1.5V Li-ion batteries. With multi-stage refresh, precision charging, and micro-current activation, it eliminates overheating, incomplete charging, short battery life, and aging issues. Smart recognition and an HD display make operation intuitive - perfect for home and professional users.
Especially, for the 1.2V Ni-MH AA/AAA batteries, we adopt xtar Unique CVSA tech enables lower temperature, ensures stable and fast charging, extending battery lifespan. And the Refresh function can also boost your old flashlight NiMH batteries back to their maximum possible capacity. :slight_smile:
Check more online:
Wonder if this new charger would charge Eneloops like they were Li-ion cells like the VC4 I bought?
Yes! This L4 PRO charger can charge the nimh Eneloops.
That’s the kind of thinking that reminds me why I’m not going to buy any more Xtar products.
My dislike of Xtar started with their charger first identifying NiMh cells as Li-ion cells and then trying to charge them that way. It got worse when they told me there wasn’t anything wrong with the charger I had.
But to be fair to them I was able to use their charger to charge the Eneloops when I first got it, but that only lasted for a couple of months.
【Updated】 XTAR L4 Pro Charger’s Refresh Function
Thanks frederikboving for testing the xtar L4 Pro Refresh function. “In this video below, I showed what the refresh function on the XTAR L4 Pro does to two LADDA 750 mAh batteries. It regains lost capacity bringing the two batteries from 709mAh / 717mAh to 750mAh/751mAh - a truly impressive result. I use the larger charger named XTAR VX4 to measure the capacity before and after the refresh.”
Tim also used the Refresh Mode on the new XTAR L4 Pro battery charger for some old eneloop AAA Ni-MH cells and the capacity improved.
【Updated】XTAR Ni-MH CVSA Charging Tech
For charging Ni-MH batteries, XTAR adopts the unique CVSA tech to enable lower body temperature of Ni-MH battery, ensure stable and fast charging, extending battery lifespan. There is the L4 Pro charger testing by Dr. lui_gough. He charges a nearly-empty Sanyo Eneloop (1st Generation) cell under the watchful eye of a Thermal Master P3 USB-C thermal camera.
“In the animation, we can see just how the charger was the warmest thing in the region, only until the final part of the charge where the cell reached a high below 29 degrees Celsius, in a room measuring about 24 degrees Celsius. This is pretty cool compared to some older Ni-MH chargers which can absolutely cook the cells, roasting them up to 50 degrees Celsius or so, which is good news for longevity. It’s also pretty complete with charging, taking about 3.5 hours which, at 500mA, would mean 1750mAh delivered which is quite close to the full 2000mAh capacity. But being a cell over a decade old and not being completely flat to begin with, this result suggests it got a full charge. It’s also noted that leaving the cell on the charger after completion where some trickling or charging restarts could happen, this did not seem to create any thermally noticeable increases in cell temperature. As a result, I can confirm that this charger treats Ni-MH quite well.
It is rather friendly and gentle on Ni-MH cells, as it uses XTAR’s CVSA technology, but also features additional discharge and refresh modes to get the most out of them.”
Check more info here:
With all due respect to Dr. Lui Gough, It would have been much better if he did a discharge test with that battery to see how much it was actually holding after the charge, plus a comparison by doing a standard “-dV” or “3dV” charge (and then a discharge) on another charger like the SkyRC MC3000 or the Gyrfalcon S8000.
The way it is, it’s hard to justify his conclusions (“3.5 hours which, at 500mA, would mean 1750mAh” → perhaps not as the charging current can vary, specially at the end of the charge), ditto “quite close to the full 2000mAh capacity. But being a cell over a decade old and not being completely flat to begin with” – these two statements end up turning his testing into something much less precise and exact than we have come to expect from him.
Just my $0.02…
【Updated】 L4 Pro charger showing “ERR” - possible causes
A customer told when charging some of his AA NiMH batteries in the L4 PRO, the battery icons on the charger’s display start blinking, charging cannot proceed, and the charger eventually shows an “Err”. The polarity of the batteries was confirmed to be correct. Besides, when using the Refresh mode, the charger behaves the same way—quickly switching to “Err.”
Based on this information, one possible reason is that theses AA NiMH batteries may have high internal resistance. During the charger’s detection phase, the voltage fluctuate significantly, which could lead the L4 PRO to classify the batteries as abnormal and stop charging. Even if other chargers could charge these batteries, it doesn’t mean the batteries are in good condition. In many cases, high internal resistance also comes with noticeable heat during charging and a significant drop in capacity, which indicates aging or degradation. Then, these kind of batteries are not recommended to use again.
Besides, The “ERR” message on the L4 PRO charger may also be caused by inserting incompatible battery types, such as 3.6V Li-ion cells, 1.5V alkaline batteries, or 1.5V rechargeable carbon batteries, which are not supported by the charger.
