【New Product】XTAR PB2SL V2 Charger
So happy to share we’ve upgraded the PB2SL to PB2SL V2 , 2-in-1 portable charger with power bank function. There are some upgrade highlights, check details online:
PB2SL V2 Main Features :
  • It has wide compatibility, applying to all size of 18650, 18700, 20700, 21700 batteries.
  • It supports multiple fast-charging protocols including QC4+, PD3.0, PPS, and AFC for efficient charging. Delivers up to 22.5W output to fast-charge your external devices with ease.
  • With dual output ports: USB-C & USB-A.
  • It has reliable charging solutions, with smart energy balance, intelligent 3-Stage charging, and low voltage activation.
  • multiple advanced safety protections.
  • User-friendly design for better using experience.
  • Portable & Easy-To-Carry everywhere.
【Updated】 About using PB2SL V2 Accessories - holder & rotating plastic piece
  • For unprotected 18650 batteries or flat-top 20700/21700 batteries:
    Please ensure the removable locking spacer is installed before inserting the battery. Failure to do so may result in poor contact.
  • For protected button-top 20700/21700 batteries:
    Please remove the locking spacer before inserting the battery. Failure to do so may prevent the battery from fitting into the slot.
  • To secure 18650 batteries more effectively: Please rotate the plastic piece in the cover to a horizontal position.
  • When inserting 20700/21700 batteries:
    Rotate the cover plastic piece to a vertical position. Failure to do so may prevent the cover from closing properly.
*Note: If you encounter issues, such as, “18650 batteries not making contact,” “The battery slot too short for 21700 batteries,” or “The cover cannot be closed with 21700 batteries installed,” please follow the above instructions to ensure proper use.
any plan to make this also fit for a smaller battery like 14500 with 0.5mA current using an adapter or so? That would be great.
Does the brand Xtar means X - Star = the unknown star… !?
I post it here too… !
【Updated】 XTAR PB2SL V2 Charger – Frequently Asked Questions
Some customers asked if they can use two different 18650/21700 batteries with different capacities in the PB2SL V2 charger. Then how about the charging and discharging processes? Yes, batteries with different capacities can be used. However, for optimal performance as a power bank, using two batteries of the same capacity is recommended.
During charging, differing capacities have no impact. The lower-voltage battery will be charged first. Once voltages are balanced, the charger will initiate fast charging input based on the adapter’s power.
During discharge, the battery with the higher voltage discharges first, without enabling fast charging output. After the higher-capacity battery is used up and only one battery is left, the device automatically stops fast charging output. In this case, the PB2SL V2 may continue supplying up to 15W via low-voltage direct charging output. However, if the remaining battery cannot sustain a 7A discharge, the protection mechanism may be triggered, shutting down output to prevent damage.
There are more details about the xtar PB2SL V2 charger’s FAQs online for your reference:
【Updated】 Comparison of different 2-in-1 Charger & Power Bank
There is a comparison chart of XTAR and a few other brands 2-in-1 Charger & Power Bank. For more details about the battery compatibility, charging performance, and user experience of these chargers. Please check here:
【Updated】About PB2SL V2 Low-Current Mode
For some small devices, such as Bluetooth earbuds, smartwatches — characterized by “low drain and low battery capacity” are in greater need of gentle charging. If these devices are charged with high-current, issues like unstable charging and device overheating frequently arise. In some cases, it may even shorten battery life. To address this, the XTAR PB2SL V2 charger is equipped with a Low-Current Mode, specifically designed for small devices to ensure safe, stable, and complete charging every time.
There are more info about XTAR PB2SL V2 Low-Current Mode here:
