Yes it’s true, I just don’t want this awesome thread to die!
If you’re having a hard time getting batteries from China, this is an alternative.
This link is still active and seems like a great deal. If you buy 4 you get free shipping and I believe he’ll take $10 per pack…24 batteries for $40, so that’s $1.67 each for 2800mAh Samsung ICRs!!
Are the ones from the black packs any better than the ones from the white packs? I just did a runtime test comparison with these –28A’s and some of the green Sony 2200mAh cells from the HP 12-cell packs.
The Sony cells last just as long as the Samsung cells (60 min vs. 62 min in my Trustfire X9)
I just received one of these yesterday Battery Pack/ebay . It contained the same purple Samsung 2800’s as the original white packs.
When I checked the cells with a DMM there were two that measured 2.01, and the other four measured from 2.71 to 2.83. I decided to keep the two lower reading batteries separate when charging as a test. This was easy to do since I have an i2 and an i4 charger. I expected the lower reading cells to take longer to charge, but to my surprise they were fully charged MUCH sooner than the four higher reading cells. I even moved cells from bays 3 and 4 of the i4 to the i2, and it still took about an hour or so to finish the charge on these cells (I purposely left cells in bay 1 and 2 since the charge rate is higher than paired in 1 and 3 or 2 and 4). I guess that is a good example of the difference in the multi-cell charge rate between the i4 and i2 .
Oh yeah, when the cells were all charged, all six read 4.21. Looks like they are good to try now.
The Samsung –28A from the white Acer Aspire packs is a 4.3v cell? This was never mentioned in the original thread for those packs. My i4 terminates at 4.16v.
I saw the cottonpickers charger while looking about, but I don’t have $50 to spend on a charger. But a charger that will charge to 4.35v is okay to use with the –28A?
4.35v is too much for these cells, just like 4.25v is too much for 4.2v cells. These will work fine at 4.2v but they lose a little capacity (~200mAh IIRC). I have several of the Samsung 28As that I gave to friends that have been using them at 4.2v without any problems. Don’t fret it!
There is also the $5 “budget” option (which I am using): CC/CV board
There are lots of good examples on how to set this up in that thread. This one is mine.
You actually have to work at it to get to 4.35v, like leaving them in there overnight, everything happens very slowly. Also, the 28A has a + or - .02 or .03v range (don’t have the spec sheet handy) so there IS some wiggle room there.
Very often I just charge them in my i4 though, they work great from the 4.19ish volts it goes to.
