The Acebeam New L19 2.0 is the Best Long Range Flashlight in its Class.
The Acebeam L19 2.0 best flashlight with black warrior style is perfect for outdoor or tactical applications.
White LED max output 2200 Lumens and throw 1083 meters/3553 feet for ultra-long range quality illumination.
Moonlight mode can last 62 days for extended law enforcement, camping, searching and rescuing.
1100-lumen strobe helps you in self-defense.
Compatible with accessories like mount and remote switch for tactical use.
Hello BLF members,
Great news!
Acebeam L19 2.0 Whole New Black Warrior is coming! It utilizes a popular SFT40 LED emitter with the self-developed TIR and a definite powerhouse with its 2200-lumen,it maintains a respectable 3553 feet (1083meters),which makes this flashlight perfect for hunting purposes or tactical situations. It is the best long-range flashlight in its class, long-range visibility helps you go undetected in the woods.The Acebeam L19 2.0 will be your new go-to hunting flashlight, and you can’t beat the long-distance capabilities. Also it is the great gift for the hunter or outdoorsman in your family.
Get yours at Amazon.US: L19 2.0 Longest Range Flashlight in its Class
Learn more: Acebeam L19 2.0 Best Long Range Hunting Flashlight
2200 lumens maximum output and 1083 meters/3553 feet maximum beam distance.
Compact size only 6.44” long and weighs only 284.3g/10.03 oz Including battery.
One US imported SFT40 HI LED with a lifespan of 50,000 hours.
Utilizes the self-developed 55 mm TIR Lens (Total Internal Reflection)to form the excellent beam pattern.
Included an Acebeam IMR21700NP-510A USB rechargeable 21700 Li-ion battery.
Dual switches allow quick and easy access to the important settings.
A power indicator helps you track the remaining battery power, letting you know when it’s time to recharge.
The strong tactical strike bezel can also be used as an emergency glass breaker.
Internal overheat prevention to protect your light.
Lockout mode, preventing accidental activation.
Made of durable high-strength and oxidation-resistance aluminum.
Premium type HAIII hard-anodized anti-abrasive finish for a durable light
IP68 rated 5m Submersible and Waterproof.
