New Release: USB rechargeable Caribiner Flashlight
Hi, today i would like to show you mecarmy new releasing LED flashlight,that is carabiner design,details as follow,
1.Made of TC4 titanium
2.Utilizes CREE XP-G2 S4 LED, max output 360 lumens
3.Max runtime of 6 hours
4.Max beam distance of 64 meters
5.Standard Micro USB charging port
6.Charging indicator
7.Powered by 100mAh lithium polymer rechargeable battery
8.Anti-scratch double coated lens
9.Titanium protector for light head
10.CNC precision machining
11.Multi colors available using different surface treatment
12.Lightweight, portable, high hardness and corrosion resistant
12.Smooth reflector
14.Overheat protection
15.Keyring attachment hole design
17.IPX5 water resistant
NOTES: Carabiner weight load is not tested, please do not use to lift heavy duty things.
What is your feedback?
If someone gave me one of these as a x-mas present, the first thing I would do is cut off that darn useless “self defense” bezel. Why did you design the light with it? It’s useless and only makes it bulkier. Top tip: get rid of it!
My thoughts too but I didn’t have the nerve to post it.
Reported you two to the mall ninja brotherhood, be prepared to be jumped by overweight neckbeard in full tactical attire.
Thanks Mike, I will pass your idea to our R&D team
I disagree. Granted, as a self defence tool it’s not the sort of thing I’d use, but it doesn’t add very much bulk, and might be useful as a pry bar type of thing.
The specs for the flashlight are clear, but what are the specifications for the carabiner? (in Newton, in the length and perpendicular)
My guess is that it just looks like a carabiner, but is not supposed to function like one. Surely it can handle some weight… But I would not put my own weight on it.
No I’m not FAT… And I’m also not big boned.
Maybe they could add a point like on the Zanflare F1 to break auto glass if you can’t get the door open after an accident. I don’t think the self defense concept is great because I don’t know how I’d get a good grip on it but the mini prybar idea has legs especially if it’s notched & angled enough to pull a small nail.
Ummm, is this the FL10? Didn’t see any pix, links, anything. Had to goggle “mecarmy carabiner” to find it.
Could make one like a set of brass-knuckles with those spiky things in front.
That’d be tres kewl…
