The Product
Nitecore sent me an early sample of the LR50, their newest lantern. This is a neutral white, high CRI lantern that is powered by 1 or 2 18650 cells, with the ability to use CR123A as backups. It charges via micro-USB, doubles as a power bank, and has a sleek and carry-friendly form factor.
While Nitecore has a whole lineup of lanterns, this is their first model that has replaceable cells and built in charging, as well as their first that doubles as a power bank.
Spoiler
I carry a powerbank with me quite often - when I travel, on backpacking trips, and sometimes just around town. I always prefer to bring one with replaceable cells as well. The LR50 works great as a powerbank, while serving double duty as a lantern or emergency light. It's water resistant, high CRI, and has a magnetic base - three of my favorite features in any light.
The UI is simple, and the configurable beam direction is useful as well. It's been jostling around my bag for over a week now, and the two-button press required to power it on means it hasn't turned on when I didn't want it to.
I'm not a fan of the two bays being wired together, and when I opened mine up one of the wires was damaged to the point that it could be dangerous. Hopefully this is limited to my sample.
Physical Dimensions
The lantern measures 120 mm tall, 58 mm wide, and 30 mm thick. It weights 109 g on it's own, and 205 g with the two cells provided for testing.
The side-by-side configuration makes it quite compact for a camp lantern, barely larger than the PB2 powerbank. For size comparison, this lineup shows it next to the Streamlight Siege X USB, XTAR PB2, Nitecore LA10 CRI, and the Zanflare T1.
Build
From the outside, the lantern is just a diffuser with a small black base.
The base has identical switches on each side, one with "LR50" molded into the body beneath it, the other with "Nitecore".
At the base is a rubber port cover, along with all the usual regulatory markings. These include an abnormally vague "max 30Wh" label. There's no mention of the expected input or output current or voltage. It's pretty obvious what can be expected from these ports, since USB is a commonly used standard, but you don't often see a DC power port without that labeling on it. The 30 Wh figure is also questionable - two 3.7V cells with a capacity of 3500 mAh each would only give a total of 25.9 Wh. If you took the charged voltage it would get closer to the 30 Wh number...
Beneath the dust cover are the two ports, USB-A for power output and micro-USB for charging. I would have liked to see a USB-C port used instead of the micro-USB for power in/out - that's the way other products on the market are headed, and it's unfortunate that no powerbanks with removable cells have gone that way yet. Four rubber plugs are visible, sealing and hiding the screws. I believe that port cover may make this one of the only water resistant powerbanks with replaceable 18650 cells, which is fantastic!
Two latches at the sides release the diffuser clips. There's an o-ring seal where it meets the base.
Removing the diffuser gives you a look at the innards. There are 3 SMO LEDs on either side and another 3 on the top, and when the diffuser is removed they are bare. The two cell bays take up most of the volume.
Each bay has a sticker indicating polarity and supported cells. The negative contact is a spring.
The positive contact is a slightly depressed brass button, so flat top cells are not intended to be supported.
What's Included
As usual with early samples from Nitecore, my sample arrived with no packaging, though Nitecore was kind enough to send some cells for testing and a USB cable. According to the manual I received, production units will include a micro-USB cable and a spare o-ring.
Ergonomics and Retention
Being a lantern, the ergonomics really aren't too important here. What matters more is how well it fits into a bag - and the smooth, slim body seems to do a good job at that. The flat base is also fairly stable if you want to stand it up, though the rubber port cover seems to stick out a tiny bit, giving it a small wobble. This might be an issue for indoor use, but campsites don't tend to have many perfectly flat surfaces anyways.
The bottom also has a stow-able hanging hook. It's a closed loop, but it can be removed without any tools if you need to hang the lantern from a cord that's already fixed on both ends.
Finally, there's a magnet in the base that's just strong enough to support the weight in any orientation. When attached with the magnet, the contact made by the rubber port cover comes in handy to stop the light from sliding around.
Modes and Interface
There are 3 brightness levels and 3 lighting directions for the lantern. The manual lists low, mid, and high as 6, 65, and 250 lumens when all 3 lighting directions are enabled. The 3 directions are:
- Both sides and the top illuminated
- Top illuminated
- One side illuminated
- Top and one side illuminated
The UI is controlled by two identical switches, and works as follows:
- From off, pressing either switch indicates remaining charge (1-4 flashes)
- From off, hold both switches to turn on the lantern in the last used direction, low brightness
- Continue holding to cycle to full brightness beacon and SOS modes
- From on, press either switch to cycle brightness
- From on, hold either switch to cycle directions
- From on, hold both switches for off
- Continue holding to blink the blue indicating LED every 2 seconds as a locator
This UI is good for the device and features it has. I wish there were a few additional brightness levels - perhaps a lower 1 lumen mode and a higher mode, but overall it's good. I'm always impressed when manufacturers manage to add features like the configurable light direction without messing up basic use of a light. It's also possible to activate fewer directions and get a lower overall output as a result.
Note that the two blinking modes do not have adjustable beam direction or brightness.
Light Quality and Beam
SMO LEDs are used for this lantern - 3 on either side, and 3 on the top. Each measures 5 by 3 mm. Nitecore says these are between 4000K and 4500K, and over 90 CRI. The color of these LEDs is great, and it's lovely to see high CRI LEDs from Nitecore.
The beam is a bit interesting. Since the LEDs are down each side, with none along the edge, it doesn't put out a 360 degree beam if it's sitting on a table. If it's hung from above, the top emitters help to even out the beam. There is no visible PWM on any mode, which is excellent to see - a lot of other lanterns I've tried suffer from this.
Power and Runtime
The light is powered by two 18650 cells. The manual states that it will also run off of a single cell, and can use 4xCR123A in a pinch. As a lantern that could see a fair bit of use in a power outage, I like the flexibility. The light requires button-top cells, as it has physical reverse polarity protection.
The manual says not to use mismatched cells. With my DMM, I measure continuity across the two negative contacts and the same across the two positive contacts. Additionally, measuring the voltage across the the empty bay when one cell is inserted shows the cell voltage. As best as I can tell, it seems like the cells are directly in parallel. This is fine as long as users are aware of it, but be sure to heed the warnings in the manual and not mix chemistries or charge levels (different capacities are likely fine). I would have preferred independent bays - one of my use cases for this product is as a powerbank on a backpacking trip, and it's nice to be able to swap out a cell for the one in my headlamp if either device is running low.
Standby drain with a single cell was measured at 196 uA. I was unable to get a good reading with two cells installed, but all evidence suggests it should be the same - that means two 3400 mAh cells would drain in about 4 years if left alone.
Runtime on high with two cells lasted 9.9 hours, which is just about the 10 hours listed in the manual. Another test with a single cell shows that the light appears to have a timed stepdown to 45% after 2 hours - as much as I don't normally love timed step downs, 2 hours is long enough that this seems a reasonable way to preserve battery life. Both tests showed the output climbing for the last 50 minutes, presumably because the driver wasn't able to regulate output with a lower voltage.
Charging
To charge the light, simply plug in a cable to the micro-USB port on the bottom. The indicating LED will blink while charging, and go solid when the charge is complete. The lantern function works as normal when plugged in. The lantern also works off of a USB power source without cells installed, but it strobes on the lower two modes - it doesn't seem to be intended for this use, and the form factor doesn't give you much reason to run it without cells.
Averaging across two tests, it took 31.9Wh to charge two 3400mAh cells. The peak charge current was a little over 1.6A measured at the USB port.
Behaviour was almost identical with a single 3500mAh cell, pulling 16.4Wh over USB.
Power Bank
To use the power bank function, just plug a USB device into the USB-A port in the bottom. The indicator LED will turn on to indicate it's in use. Nitecore states the powerbank can supply up to 2.1A.
A constant current load of 1A didn't have any issues keeping the voltage healthy, and drew 21.44Wh from two 3400mAh cells, 10.50Wh from a single 3500mAh.
Repeating the test with a 2A load, the power delivered from 1 and 2 cells is 21.16 and 9.68Wh, respectively. Nice to see no major loss in efficiency at the higher loads.
Currents of up to 2.1A are supported, but a quick load sweep shows that the powerbank doesn't cut off up to 4A (that's as high as I can test with my load). The voltage from a single cell dropped below the acceptable 4.75V at the upper end of the test.
Trying to pull that much current for any sustained amount of time isn't a good idea - a 3.6A load from two cells shows the voltage falling out of spec after a little over a minute, settling closer to 4V. The unit didn't get noticeably hot on the outside, but something smelled a bit toasty - it's possible that was the small constant current load I use as well. I would have liked to see improved over-current protection here. Fortunately, most common devices like cell phones won't try to charge at this rate anyways.
Teardown
Summary
Pros:
- Good form factor combines a slim build with high capacity
- Dual lantern and powerbank features are a useful combination
- Warm white, high CRI beam is excellent for a lantern
- Configurable directions let you use the lantern as a work light or reading light without wasting power throwing light in directions you don't need
- Magnetic base and bail for hands-free mounting
- Flexible power options
Cons:
- Damaged insulation on the leads is a dangerous defect in my sample
- Over current protection doesn't seem to work very well
- Cells bays seem to be directly in parallel - independent bays would be preferable
- I would have preferred a USB-C port over the micro-USB
Notes and Links
This product was provided free of charge from the manufacturer. I was not paid to write this review, and have tried to be as unbiased as possible.
