Do you have a D4S? I machined the guarding around that switch down…all men created equal, not entirely true, I was called Da’Gorilla when I wrestled in high school/college, I’m sure we have different thumbs ![]()
I tried it in the freezer and it still won’t budge, I must not be getting enough grip or the threads are slightly stuck.
This flashlight can be easily disassembled if heated up to 60°С. You can even try to use the Turbo mode. Also it better be done in gloves, in order to avoid burns and quick cooling.
The bezel isn’t glued and usually can be unscrewed by pressing it against something rubber, like shoe or linoleum. I’ve used two-sided duct tape sticked to table.
How is the efficiency compared to 7135 current regulators?
It’s me, in a way! I’ve spent all my childhood…
Interesting and in a sense heartwarming story. Thanks for sharing!
However, the show also has male fans called “bronies”, which serves as a way for men to rebel against traditional gender roles… but this often brings controversy. It tends to be a political topic, and the brony community has been ridiculed by conservative media.
With all due respect, I don’t think that it is right to look for any political undertones in brony culture and/or portray them as people who are fighting so-called gender stereotypes, because that is not what they are. ![]()
It tends to be a political topic, and the brony community has been ridiculed by conservative media…
Unfortunately politicians or activists often use popular topics that are alien to them to push their bias and this happens on both sides…
I like the unicorn theme. I often have a purple flashlight clipped to my purse, and sometimes even wear matching earrings or shoes. But most flashlights focus on more masculine and military themes. For example, Warrior, Armytek Predator, Intimidator, Dominator, Raider, Fury, Marauder, Titan, Siege, and things like tactical strike bezels.
These model names have reminded me of one peculiar keyboard. ![]()
Trust me, a lot of men, including me, don’t like pretentious overly aggressive names like Predator, Intimidator, Dominator, Raider etc too and prefer something more neutral, but employees who are responsible for marketing think otherwise. As for YLP’s Unicorn I like the unicorn theme too. In my opinion it was as a whole a good choice. Unicorns can be intimidating and strong, for example, AOKP emblem, or cute and fluffy like the ones on your screenshot, so this emblem most likely will appeal to a wide audience. MLP reference and the way it represents Inferion as an engineer that designed this flashlight is also nice.
By the way, in my opinion, you should start branding the flashlights that you designed. A small picture of the Goddess of Light would be very cool. ![]()
Nice light, very well built excellent quality, absolutely LOVE the design/knurling and the UI is outstanding…but the area around the switch needs to be machined down closer to the switch retaining ring, I have to use the thumb nail to activate, not a fan of the optic, emitter looks abit off center on a white wall and it is ringy but is acceptable outside, also my OCS would not allow the off indexed battery tube and tail cap. So I machined the tube and cap to align with the switch… and added a couple of trit’s I had laying around…
Wow! Now I'm disappointing with my Unicorn. The pics on the website show the parts all aligned, just like you customized yours to be -- this is very disappointing now because clearly I can't do that kind of machining...
I'd make the frown bigger if i could...
I blame KB for pointing this out ![]()
Dang, I can't unscrew the head from the tube, not sure I could for a while because still recovering from rotator cuff surgery on my good side (left), so don't have full strength yet.. Once I get it apart, maybe just some sanding down to get them to align - think there's some slop to work with.
Nice flashlight, such a better Olight S2 ![]()
Good job, Inferion!
More photos:
https://www.torch.pl/forum/index.php/topic,64365.0.html
Great size comparison!
Cracked the bezel open and filed down the 2 legs of the optic cup down, it wasn’t sitting square to the mcpcb and allowing the optic to engage the emitter pad, now all my rings are perfectly spaced… spot is more centered instead of cantered/off center like it originally was…
Machined the switch guard flat just need to buff on the wheel to a mirror finish, 1200grit finish for now…
Much much better for me now….
Now to find a decent clip to mount to the tail cap opposite the switch…
Very smart. Any accidental pocket activations yet?
Won’t know until I actually EDC it… looking for a clip to mount first…I throw the clip on clips into the garbage…… can’t stand them…
I made a hardware abstraction layer and UI toolkit called FSM
This? E-switch UI Development / FSM
I’ve wanted to divide the system part and UI for a long time, so that UI could be written in C and uploaded as application in the binary form. However, I still don’t know, how to implement it in high-level programming languages, where you can’t just point at resources that compiler and linker have the rights to utilize. It is possible to write the system part on Assembly, with loader and API, which calls the UI function with the frequency of the main cycle (60 or 100Hz). But how to write application software in C for this? So that the compiler wouldn’t use registers used in interrupts, so that it wouldn’t try to initialize the stack, etc. It’s easier with Memory: you can explain to the linker where and what to put, but with the core…
Do you have any ideas on this?
I just set mine up for UI 2 - smooth ramping w/switch LED always ON - looks like my favorite. Also I like the smooth brightness control for all transitions, both to ON and to OFF, as well as all mode switching. All around this is a lot of features for the money. Really like your switch mod, KB, and the trits - I'll see if I can attempt them.
The smooth ramping is decent - overall time is reasonable, not too long - nice job on it!!
Mine came in yesterday. Love the design, form factor, and the ramping UI. My LH351D has some tint shift/noticeable green in the corona, but I don’t notice it in real world usage. Definitely better than Cree and also not as green as some SST-20s I’ve seen (although the FW3A SST-20s look nicer.)
My only issue with it is sometimes when on after ramping, a single click will not turn the light off. I guess it’s treating the single click as potentially the start of a “hold.” I have to wait a full second after any ramping in order for a single click to turn the light off. A little annoying, but I’ll get used to it.
Is Skilhunt (or whoever their OEM is, if they use an OEM) making this light? It reminds me of the H03, especially the switch, although thank goodness it isn’t long press for off (which is intolerable IMO.)
That’s funny, I thought the design looked very similar to Acebeam. I guess we’ll never know!
And I’ve noticed the same with a single click after ramping.
That single click after ramping will do a little “bump” in the opposite direction you ramped, in case you overshot the brightness you wanted.
It’s mentioned in the advanced manual but not the included one IIRC.
I’ve only tried it briefly, but I like it. I don’t anticipate any pocket-activation for me, as I clip to the pocket. I think even KB’s will have a very hard time misfiring. They did a good job there. (Hank, are you taking notes?)
Totally unnecessary function, IMO. Besides, great UI ![]()
I just ordered mine. This (to me) is an interesting new light. I am over all of the multi-emitter, catch-your-pants-on-fire, wall of light, pocket rockets. I want something small with a more focused beam and a ramping UI.
Oh right, I forgot about this one. I’ll be very curious to see a few quality reviews for this one. It was trying to be a Zebralight but better and cheaper, iirc. I had a rough time on that Russian website with google translater a while back…
Edits: $38 is not bad. bmengineer and others, I’ll be extremely interested in an evaluation of the side-switch for pocket activation. As in, that alone will likely 100% determine if I end up ever buying this light. Looks to be ~6mm longer than my SC62, which is probably about the difference between having a separate driver from the MCPCB, and not.
Hopefully it gets sold in some more convenient places.
I’ve been looking for a successor to my sc62w.
The button on this is both recessed and stiff. It ticks a lot of the boxes I had on my list of what might be good. While the 62 was nice and compact I wished it was a bit longer to fit my hands better when using the light. I wear a size 12 glove. I also wanted a beam with a bit more throw and was thinking a tir optic might do the trick without getting too long.
I have yet to run it through my usual tests other than some dark room white wall comparisons. Tint is nice. The ui is very practical. The knurling is very well done.
That being said while it feels good in the hand is going to tear up pants long term. Also clip on clips are not my favorite. Machining is really nice Asia the anodizing, but my sample the tube is clicked and the y shape in the knurling didn’t line up with the head.
It’s a very nice light for the money.
