Didn't see that coming...
This is even better than i was thinking it could be!
Clemence, thanks for all this test data. It definitely provides confidence in your boards.
Will you be offering those optics through your store, or can you share the source (especially for the microlens version)?
Also, will you be offering either of the VR16SP4 boards trimmed to fit in Armytek’s as you have in the past? Thanks!
Indeed.
Now…any news about 3x3 boards?
Savage....
I think I’ll skip that for this…
[Clemence]
Clemence, you caught the wave...
Interesting…but too large for the 20.6 mm diameter light that waits for it.
ADDED: though without the corner LEDs the following 12 would have just 0.42 mm larger diameter than 9….
ADDED: About 10-12A when driven off 16340? A hottie.
Too sleepy to continue, will post the beam shots tomorrow…
[Clemence]
^ That looks like exactly what I’m planning on doing: RGBA quadtrix (in an S2+).
I’m hoping to find a better 4-channel driver than the single mode per channel model that kaidomain sells, but even if not, I will enjoy experimenting with these.
Clemence, is that 4x4 still going to be 35mm? If so, it won’t be able to fit in any flashlights
Clemence, is that 4x4 still going to be 35mm? If so, it won’t be able to fit in any flashlights :weary:
That 4x4 E21A requires big 13mm LES class COB optic to work properly. With smaller than 35mm (ideally 50mm) the wiring will interfere and creates artifacts unless special flat wires which is not common is used. With 30mm diameter it’s uses are even more limited. And another reason is the heat spreading factor which is a very important factor for non isolated thermal pads in E21A. Larger the diameter is better. Above thermal simulation shows that to get into BLF output range (8500 lumens in R9080 or 12.000lumens in R70), 0,21mm (6 oz) thick copper trace is needed (with current best IMS available)
[Clemence]
Without corners it has LES not much bigger than XHP70.2…
Yes I know, and it’s designed to work with 4 - 16 LED
[Clemence]
BTW a 21 emitter config like that
would have merely 0.4 mm (3.2%) larger LES diameter than than a 16-up.
E17A Color mixing (Red, Green, Blue, Amber)
White matte PVC LED holder only
20mm Plastic aspheric, 15mm focal length
20mm 10° polished surface, plain TIR lens
20mm 15° frosted surface, plain TIR lens
20mm 25° microlensed surface, convex center TIR lens
20mm 30° frosted surface, convex center TIR lens
20mm 40° microlensed surface, convex center TIR lens
20mm 60° microlensed surface, convex center TIR lens
20mm 90° frosted surface, plain TIR lens
20mm 110° microlensed surface, convex center TIR lens
[Clemence]
A best color mixing are produced with elliptical TIR and VR16S1+2 different CCTs parallel led. I tested sm303+sm653 may be 95% dissolves on both, only minor singularities on edged. Non-elliptical TIR does performing mirred of source.
Please returned VR16S1 on store
LES is not my only concern with all my module designs Agro. Voltage flexibility is mainly limits the design. Beam profile can still be altered by optics, easier than voltage.
[Clemence]
Yes, I will later
[Clemence]
Wow, no donut hole with the 30dg Lens? But the Beam Has a weird shape the 15dg frosted lacks.
