I saw, but shipping would be complicated for my location. If someone could sell them on Aliexpress, probably more people would be able to buy. Iāll end up using 219c 5700K.
can anyone help guesstimate the lumen outputs of 519a compared to sw45k, when using an RRT-01 host and driver? and or when using a FWAA host and driver? or SP10 Pro Host and Driver, on AAā¦ , or in an AAA Tool?..
trying to understand if the 519a advantage is large or small, in the lights I useā¦ at the power levels they operate at.
A guess from the provided graphs.
RRT-01 around 200 lumens from start up full battery.
SP10 Pro from GC harts graph maybe 50 lumens from a AA.
AAA tool probably around 10 to 20 lumens.
The FWAA not sure.
It could be slightly higher than my estimates given the lower vf of the 519a.
I estimated given the drive current per output.
Do you happen to have the raw data behind this chart at hand or did you dispose of that already? Iād like to compare efficacy and luminance as wellā¦
I remember Bobās test but can not find it now. What were his numbers? (I tested in the hotspot of a smooth reflector, not on the bare led, did Bob do that too?).
Btw, the Duv is dependent on current, at lower than 2A the CRI goes up a bit and the duv also, getting even slightly positive, at higher than 2A the duv is lower and CRI goes down a bit.
Djozz, before tossing the damaged emitter, could you slice the dome? I wonder if the new glass+silicone design makes it easier. I would also expect the amount of decrease in output, cct, duv to be different from emitters with homogenous dome composition.
Thanks! Yes, so all sorts of reasons why his tint differs from mine, batch variations, tighter colour bin, perhaps a different current, and a different optic (a reflector hotspot that does not use the light from the cone straight above the led tends to increase the duv more than a TIR optic (that mixes light from all directions).
Thank you. Iām not into pixel counting now and I see that I donāt actually have apparent die size of 519 but at least I can compare efficacy.
And LH351D wins big time, needs ~10W to reach 1000 lm while 519 needs ~12.5W. At other currents the difference is similar, though slightly lower at the extremes.
Thatās sad, I hoped 519 would be at least close. But it is what it is.
