I dont think the Max lumens matter
the 519a has a larger hotspot, so it might work in place of the XM-L in a Sunwayman V11r,
instead of using LH351d that has lower R9. The 219b does not make a good beam w an XM-L reflector.
btw, slicing ruins the beam of an LH351d in an XM-L reflector…
so I see no benefit to slicing a 519a… it gives up all the size advantage, that could make it compatible in an XM-L reflector or Tir.
the 519a might also be viable to replace an Olight XM-L2…
not sure… I put a 219b in an Olight, but replaced the clear XM-L Tir w a Pebbled Tir, to fix the shadow artifact in the center of the beam, caused by the smaller 219b when paired w the stock clear XM-L Tir
the 519a is less pink than the sw45k, and is more similar in Tint DUV to the sw35 and sw40. So, choose 519a for the 2x larger hotspot, if the tight hotspot of 219b is not suited to the application or user preferences. Or for lights where 219b does not work to replace an XM-L due to beam issues, the larger dome of the 519a might produce a cleaner beam.
