Life long fisherman and great white hunter of nightcrawlers but have found that these day they are much faster than they used to be and I need to become a more effective stalker.
Looking for a headlamp with a BRIGHT red emitter. I have a few older headlamps but they dont put out enough light and are worthless unless held near ground. Would be much easier to wear on head and I am pretty sure that is why they have a band.
DW4 with red SST20 or W2? (does 660nm vs ~620nm matter?) Probably get the boost driver for sustainability, if you donβt need a white mode too. With white W2 or SST20, would be ~4000lm non-boost or ~2000 boost.
I have an Ozark trail 500 lumen headlamp I use for catching crickets and worms. I grabbed it on clearance for $7 at wally world. I figured hard to beat that for a rechargable lamp. I liked it enough I grabbed 4 more just for the battery packs and parts if I ever need to replace.
Just get a good headlamp, like the Boruit D10, take a small red balloon and cut off the tip, and then stretch it over the head. Lots of red lumens to find those nightcrawlers!
Looking forward to next Saturday, the first Saturday in May, for the official first day of fishing here in Wisconsin!
Well I ended up buying a D4 in red with boost and RGB but the problem now is yes it works great and does not scare the night crawlers BUT I cant see diddly squat using a red light.
Anyone interested in a red head or entire light in green? About 10 minutes of use.
