You’ve seen those runtime graphs where alkaline battery sputters almost immediately and
rechargeable nimh gives nice long regulation and runtime? Me too, but I wondered whether
this was the whole truth.
I decided to do a real world test, where I would run a light in small, 3-minute increments,
with an hour or so between them. This is more in line with actual usage. Even better
test would be to run one burst per day instead of per hour, but I thought I’d do this quick
test first and see what the result is. It took 3-5 days to complete the test for each battery.
Conventional wisdom with alkalines is that their capacity depends on how much current you’re
pulling from them. The higher the current, the lower the capacity. So continuous vs burst
running them shouldn’t mean big difference if the current required stays the same.
But then again, they seem to regain some strenght when left unused, and I wanted to
test whether this affected the overall runtime.
The thing I wanted to know in this real world test was how much usable light a flashlight
would provide when run in increments vs continuously. For this test I defined “usable light”
as 6 lumens. The light I was using was Singfire sf-348. Batteries were a 900mah eneloops and
some generic supermarket alkalines.
Here’s the first graph, alkaline vs nimh in continuous run. Alkaline loses.
Now, what if you use alkaline in short bursts? Each peak in the graph is the start of
a 3 minute run. Does that change anything? It sure does after 30 min mark.
Ok, now it’s nimh’s turn. Is there any performance change in real world testing? Yep.
And in the final graph there are both burst results:
I have to say this is a result I didn’t expect. While the graph doesn’t look all that
amazing, alkaline does provide THREE TIMES as much usable light when used in burst manner vs
continuous, whereas nimh goes the other way and actually degrades a bit (and I tested 2
batteries to be sure). Nimh does hold longer in regulation, but after 60 minutes you’re going
to wish you had gone with alkalines. That being said, I’m not giving up my nimhs anytime soon.
What this test shows is that continous runtime testing does not correspond 100% to real world,
and that alkalines aren’t as poor as I previously thought.
