I received the Nitecore Bubbles from Nitecore for the Review
The Nitecore Lamp is a simple, round shaped ambient light, featuring 4 HICRI emitters. It can be powered by 3xAAA batteries, or a single li-ion HLB1300 from Nitecore. The Nitecore Bubble has a string with 2 magnets, allowing it to be attached to metallic surfaces or looped around objects. It is available in several colors.
The Nitecore Bubble mesures 72mm in diameter, and considering also the loop, it measures 132mm in length, with a weight of 60 grams.
The Nitecore Bubble comes in this box.
Inside the box: the light , 3 AAA alkaline batteries, and the manual.
The part around the emitter is made of a soft silicone, and is translucent, allowing a good 360 diffusion of the light.
The “tail” with the 2 magnets.
The top plastic part has a dent in it, it’s a touch sensor that is used to control the Bubble
Twisting the top part, you can either open it, exposing the battery compartment, keep it off, or activate it (and then you can control it with the touch sensitive area)
Runtime
UI
My thoughts
The Bubble is well made and finished.
The regulation is good even with alkaline batteries, being able to balance output and regulation.
With a max output rating of 100 lumens (according to the specs), we are not in front of a super powerful flashlight like many other Nitecore, but rather a low budget, lower output flashlight that has the purpose of providing soft, warm, HICRI diffused light in a tent while camping or in a small room.
I found the interface clear and easy to use, with a lockout available, but a few times I had trouble finding the switch.
I like the candle mode for ambiance purposes. The IPX4 rating is appropriate for the intended use.
Thanks to: AntoLed, Won, Zampa.
