So I got my second EC4S in the mail earlier this week. I really like the form factor and figure I’d leave one lightly modded and use my first screw-up as an experimental host.
Anyway, successful mods are as follows.
First thing about the light that made me tear into it so fast the first time was the CW emitter. I just can’t deal with them… Second one was no different. In with a 5A.
Copper board IS NOT DTP!! Also, the negative pad is connected to the thermal pad, and the trace doubles as a heat spreader. I used a dremel to grind through under the thermal pad exposing the Cu underneath (the body of this light is isolated from all circuitry, so no worries about shorting).
I also moved the thermistor directly to the switch board and eliminated the wires, therefore, thermal throttling is disabled (aka always running max current possible).
I wasn’t brave / patient enough to go after the sense resistor this time, but will eventually probably.
I also modded the positive contacts on the driver and tailcap with 5x2mm brass buttons. The stock light doesn’t make contact with unprotected cells, and it happens that they are all I use. They could still use a little more shimming to improve bump tolerance, but I’ll likely just mod/replace the springs next.
Turns out I was unhappy with the beam and tint of this XHP-50, even after the NW swap. More specifically, there was a bad yellow/green corona and a donut cross… I contemplated for a moment dropping in an 4000K MTG2, but decided against that after realizing an easy (win-win) solution to the root cause of the focus/tint issue. Using a Noctigon (.38mm thinner than stock MCPCB) plus an adhesive 3M XM-L insulator/spacer (.38mm) under the stock centering ring fixed it right up. I’ll have to test if lux improved too, but that will be another day…
Hope this helps someone else. It sure made me happy with the light! It’s a light, functional, and practical mod that fixes most of the stock lights issues.
