I feel the need to chime in and B*$&% a little about the standby drain. Total BS. Drains two high cap cells in just a few weeks. I actually bought two of these as I ruined the first one after an alligator clip popped off and shorted out the driver while I was characterizing it. I felt so bad about ruining the stock driver…. for a minute. Now, I realize I didn’t lose too much. I’m eventually going to do some hi power - hi CRI mod. It really is a great and unique host capable of dumping a lot of heat.
As I mentioned, I bought my ec4s as an emergency search (and rescue) torch.
First time I came to REALLY (L&D situation) need some serious lumens it wouldn’t even turn on. 2 weeks without a charge of the eagletec 3500mah 18650s.
Ended up using my trusty Thorfire VG10 that night. Did the job, but proved that the best torch is the one that works when you need it most !
My solution for the parasitic drain is using unprotected batts that I can disconnect after each use by loosening the tailcap 3-4 thumb turns. Then before each use, I re-tighten the tailcap. Works like a charm.
I was under the impression they had fixed that in the S model? I was very fond of the EC4 form factor initially, but the high parasitic drain definitely took away some of the usefulness as a high power light to keep handy if I have to keep extra cells around as well.
I have the EC4S that I bought from Banggood, and I do find that the parasitic drain is rather high.
I think it is a known issue with some of Nitecore’s flashlights that using dual-electronic switch such as EC4 families, EC11, TM16, etc.
Thanks OP for posting this. I almost bought one of these, glad I didn’t. In fact, I’m done with Nitecore until they put a service center in the US like Olight has. I had a DOA MH27. Nitecore never answered my emails, and Banggood gave me a two month major hassle.
That explains a lot… I have a Nitecore EC4, won as a giveaway from OL. I really like the light, it’s a good combination of output/runtime/size/features. I had a couple of unprotected laptop pull cells; these were very good cells from a newer laptop pack that had seen little to no use. I had put the light away for a while, unaware of the parasitic drain. When I needed the light, it wouldn’t power on, so I checked the cells and found that they were at less than 1V. I had to toss those; maybe I should invest in a matched pair of protected cells to keep this from happening again.
