Is a Panasonic charger necessary? Can I use I2 instead?
Thanks.
Thanks.
I charge with an I4. For now any problem.
hey mate the Nitecore i2 will be fine for charging any NiMH batteries because it is smart charger it will be a better job then most Panasonic chargers (most of them are just a timer charge) but the i2 may under charge the batteries slightly nothing major.
you can always take them of then put them back on if need be.
Here is HKJ’s review of the 2014 i2 model
It adds a trickle charge to the NiMh charge cycle so will fill an eneloop better, but batteries must be removed within a few hours of the charge finishing to avoid overcharging.
Yes No Yes
G'Day WWEFANS aka Rey, ![]()
The Nitecore D2 (& D4) are much better at charging Eneloops (compared to the Nitecore I2 & I4 version 2).
Please refer to HKJ's review:
Test/Review of Charger NiteCore Intellicharger D4 | BudgetLightForum
https://budgetlightforum.com/t/-/29758
Best Regards,
George
Thank you.
same question as one of the posters but different charger
Will The nitecore i8 be ok for charging eneloops??
