Take the MH12S (a 21700 light) and compare it against the Fenix PD35 v3.0 which uses a 18650. Same lumen output, same throw but on the spec tables the Fenix somehow gets 30min more runtime on turbo despite having nearly 50% less battery?
I was bamboozled by this at first, LED efficiency couldn’t possibly explain such a physics-defying difference but it’s only when you look closer at the Nitecore specs you notice that they show turbo runtime “without thermal regulation”. This is absurd, it’s impossible to use it in any real-world scenario without this regulation unless you want to just have a total 45min of very brief bursts. Nobody uses a flashlight like this. I actually cancelled an order for a P10i last year because of the poor runtime spec, but again it’s not the real story. On max output according to reviews the MH12S will actually last about 3 hours, more than twice the runtime of the Fenix which is obviously much more in line with what you’d expect.
Maybe some people need the other number for specific use-cases but I can’t help thinking Nitecore are losing sales by quoting runtime in this unusual way.
