After the MT2C Pro, Nitecore also updates the smaller MT1C with a more powerful version, with higher performance, which uses the new NiteLab UHi 20 LED. The word “Pro” is added to the name to indicate that inside we find the new LED of the UHi series born from the collaboration between NiteLab and Nitecore.
Nitecore MT1C Pro is a lightweight (53g) EDC flashlight with a palm-sized footprint, suitable for concealed carry, which features a single switch at the tail to manage 2 light levels (Low and High).
MT1C Pro uses a UHi 20 LED with a maximum output of 1,000 lumens with a maximum throw of 360 meters and is sold with a rechargeable lithium battery in 18350 format, with a good 1600mAh with a maximum autonomy of 16 hours. MT1C Pro is a versatile flashlight that can also be powered by a CR123/RCR123(16340) battery.
It is IP68 certified (2 meters submersible) and has shock resistance up to 2 meters.
Its compact size and features make it an ideal companion as a backup flashlight for many uses such as outdoor activities, camping, night walking, hiking and trekking, emergency, fishing and more.
Key Features:
- Utilizes a UHi 20 LED with a maximum output of 1,000 lumens
- Maximum peak beam intensity of 32,500 cd and a maximum throw of 360 meters
- A combined optical system with crystal coating and “Precision Digital Optics Technology” (PDOT)
- A single tail switch controls 2 brightness levels
- Powered by a high capacity 18350 lithium-ion battery, compatible with CR123 / RCR123 batteries
- Includes a NITECORE 18350 rechargeable lithium-ion battery (NL1816R 1,600mAh) with a built-in USB-C charging port, providing up to 16 hours of runtime
- Highly efficient constant current circuitry provides stable output
- Built-in Advanced Temperature Regulation (ATR) module (Patent No. ZL201510534543.6)
- Electronic reverse polarity protection
- Double-sided anti-scratch coated optical lenses
- Made of aircraft-grade aluminum alloy
- Military grade HA III hard anodized finish
- Rear mount capability
- Stainless steel clip included
- IP68 waterproof and dustproof rating (2 meters deep)
- Shockproof up to 2 meters
Specifications:
Length: 88.0 mm (3.46")
Head diameter: 26.8 mm (1.06")
Tube diameter: 21.4 mm (0.84")
Tail diameter: 24.4 mm (0.96")
Weight: 53 g (1.87 oz) (battery not included)
Warranty Service
The defective product can be replaced with a replacement through a local distributor/retailer within 15 days from purchase. After that, all defective/malfunctioning NITECORE® products can be repaired free of charge within 60 months from the date of purchase. Beyond 60 months, a limited warranty applies, covering the cost of labor and maintenance, but not the cost of accessories or spare parts.
Nitecore MT1C Pro arrives in a small Black/Yellow cardboard box with writings that report the main features that distinguish it. Inside the package we find, in addition to the Nitecore MT1C Pro with the Clip installed and with the Nitecore NL1816R lithium battery inside, the USB-C charging cable, the lanyard, spare O-ring, manual and warranty.
Nitecore MT1C Pro is constructed from aluminum alloy with a military grade HA III hard anodized finish. The body design is similar to the recent MT2C and Nitecore’s latest products, featuring a thick texture that gives the MT1C Pro a good grip to maintain a secure hold even with wet hands or when wearing gloves. Nitecore MT1C Pro is really small and well made.
The total length is 88mm with a weight, with battery and Clip, of 80g. Nitecore MT1C Pro is sold with the Clip already installed (but detachable), held by three removable screws, longer than half of the new EDC. Nitecore MT1C Pro fits well in a pocket or jeans even without being seen thanks to its small size. Thanks to the tail design Nitecore MT1C Pro can be placed upright (candle-shaped).
On the head of the Nitecore MT1C Pro we find a smooth bezel and optical lens with anti-scratch coating on both sides with “PDOT” technology. The LED used is a NiteLab UHi 20 with a maximum power of 1,000 lumens.
The rechargeable lithium-ion battery NL1816R, found in the sales package, is a Nitecore in 18350 format with a large capacity of 1600mAh with a maximum continuous discharge of 3A, equipped with a USB-C charging port (5V-1A). With this battery the maximum autonomy reaches 16 hours. Nitecore MT1C Pro can also be powered by other batteries in the 18350 format, or by CR123/RCR123 (16340) batteries.
The full charge time, measured in my tests, is about 2 hours (Charging via 5V/1A adapter). During the charging process, the red charging indicator lights up constantly. When the battery is fully charged, the charging indicator turns solid green.
At the two poles, for contact with the battery, we find a plated button on the positive and a spring on the negative. Nitecore MT1C Pro has electronic protection against reverse polarity and waterproof and dustproof classification according to IP68.
The Nitecore MT1C has a single switch at the tail. The rubber button is a decent size with a perceptible click and a decent resistance to pressure. At the tail we also find the space to insert the supplied lanyard.
Nitecore MT1C Pro next to the Nitecore MT2C Pro and next to other flashlights.
USER INTERFACE (UI)
The user interface of the Nitecore MT1C Pro is simple, having only two light levels that can be activated via the switch at the tail. As already said for the MT2C Pro, even for the smaller MT1C Pro I would have appreciated an intermediate level of 300 or 400 lumens, in addition to the two available, for better management of the light output, although, in this case, I will use the MT1C Pro mainly as a backup flashlight.
NL1816R:
HIGH: 1000 lumens, 1h15min
LOW: 50 lumens, 16h
Instructions for Use
Momentary Tactical Illumination
For HIGH (default): When the light is off, hold down the power button halfway to momentarily access HIGH. Release it to turn it off.
For LOW: Turn off HIGH, then press and hold the power button halfway within 2 seconds to momentarily enter LOW. Release to turn off.
Note: If the light is off for more than 2 seconds, pressing and holding the power button again will automatically return to HIGH.
Turning On and Off
Turning On:
For HIGH (Default): When the light is off, press the power button all the way until you hear a click to enter HIGH.
For LOW: Turn off HIGH, then press the power button all the way again within 2 seconds to enter LOW. Turning Off: When the light is on, press the power button all the way until you hear a click to turn it off.
Note: If the light is off for more than 2 seconds, pressing the power button again will automatically return to HIGH.
ATR (Advanced Temperature Regulation)
The built-in ATR technology adjusts the MT2A Pro’s output based on the working conditions and surrounding environment to maintain optimal performance.
BEAM and RUNTIME
The Nitecore MT1C Pro is small but powerful with a clean beam without artifacts with a bright white hotspot with a yellow/green colored corona. The illumination angle is not wide with peripheral illumination starting after about 1 meter.
In the photo below we see a wall test of the MT1C Pro (UHi 20 LED) together with the MH12 Pro (UHi 40 LED).
From tests done with the OPPLE Light Master Pro, at about one meter away from the sensor, the value of the color temperature CCT and the color rendering Ra, in the High level (1000 lumens), are respectively 5475 for the CCT and 61.7 for the Ra. The calculated Duv is equal to 0.0148 with a green/yellow approach. No PWM visible to the naked eye.
Nitecore MT1C Pro with NiteLab Uhi 20 LED has, despite its small size, a decent range allowing a decent view of the walk even with the low level of 50 lumens. The values in candela (lux/1 meter), found by me with measurements at 3 meters and 5 meters are equal to or superior to those “in the table”.
The Runtimes were done indoors at a temperature of about 25°C, using the supplied battery (a 18350 1600mAh) fully charged and a VARTA CR123A primary battery (3V).
I would like to point out that the values expressed in the graphs should be considered primarily as a reference because they were made with means and conditions different from those used in the laboratory.
With the High level, from 1000 lumens (18350), there is a sharper drop in brightness after about 2 minutes from start-up. Subsequently, there is a slower drop for over 13 minutes before the light intensity stabilizes at about half of the initial one. Subsequently, after a slow drop, there is a sudden drop after about 70 minutes from start-up which brings the brightness to the low level of 50 lumens. Nitecore MT1C Pro turned off after more than 3 hours from start-up.
Another test was done by powering the MT1C Pro with a primary battery RC123A (VARTA, 3.31V).
With this battery the brightness, with the high level, is 500 lumens at start-up. After about 7min30sec from switching on there is a small drop in brightness for about a minute. At this point the brightness stabilizes for almost two hours before dropping further due to battery exhaustion.
With both batteries used the times declared by Nitecore in the user manual were reached.
The first 20 minutes.
VIDEO Unboxing and Use
CONCLUSIONS
After the update of the MT2C “Pro” Nitecore also updates the smaller MT1C which now adds the “Pro” writing.
MT1C Pro is well built and is powered by a high-performance lithium battery in 18350 format with a good 1600mAh which has a USB-C charging port. The new Nitecore can also be powered by other non-proprietary batteries, something always appreciated by everyone, and by primary batteries in CR1323 format. The NiteLab UHi 20 LED with which the MT1C Pro is equipped and the decent-sized optic, the same as the MT2C Pro, give the small EDC a notable throw with a very bright Spot and Spill.
The autonomy is also good as can be seen from the runtime graph.
Even on the MT1C Pro we only have two light levels. An additional level of 300 or 400 lumens, in addition to the two available, would have brought the benefit of a better usability of the same.
In conclusion, the Nitecore MT1C Pro left me very impressed; I think I will use it often in the coming months considering the pocket-sized dimensions, which make it a very versatile product, combined with a powerful beam and good autonomy.
------ My YOUTUBE CHANNEL ------------------------------------------------
