Nitecore MT2C Pro Review - 1800lm, 520 Meters
Immagine
Nitecore MT2C Pro was sent to me directly by NITECORE for review.
For technical details and to purchase the torch:
https://www.nitecorestore.com/MT2C-Pro- … t2cpro.htm
Immagine
Nitecore replaces the previous MT2C now out of production (XP-G2 R5 and 390 lumens) with a more performing and updated version that uses the new NiteLab UHi 20 LED. The word “Pro” is added to the name to indicate that inside we find the new UHi series LED born with the collaboration between NiteLab and Nitecore.
MT2C Pro is a lightweight EDC flashlight (64g), which has a single switch at the tail to manage 2 light levels (Low and High).
MT2C Pro has a maximum output of 1800 lumens with a maximum throw of 520 meters and is sold with a rechargeable lithium battery in 18650 format, 3600mAh with a maximum autonomy of 28 hours. MT2C Pro is a versatile flashlight that can also be powered by two CR123/RCR123 batteries.
It is certified IP68 (2 meters submersible) and has shock resistance up to 2 meters.
Its compact size and features make it an ideal companion for many uses such as outdoor activities, camping, night walks, hiking and trekking, emergency, fishing and more.
Immagine
Key Features:
• Utilizes a UHi 20 LED with a maximum output of 1,800 lumens
• Maximum peak beam intensity of 67,000 cd and maximum projection of 520 meters
• A combined optical system with crystal coating and “Precision Digital Optics Technology” (PDOT)
• A single tail switch controls 2 brightness levels
• Powered by a high capacity 18650 lithium-ion battery while compatible with CR123/RCR123 batteries
• Includes a NITECORE 18650 rechargeable lithium-ion battery (NL1836R 3,600mAh) with built-in USB-C charging port, offering up to 28 hours of runtime
• Highly efficient constant current circuit provides stable output
• Built-in Advanced Temperature Regulation (ATR) module (Patent No. ZL201510534543.6)
• Electronic protection from polarity reversal
• Double-sided scratch-resistant optical lenses
• Constructed from aircraft-grade aluminum alloy
• HA III military grade hard anodized finish
• Tail mount option
• Stainless steel clip included
• IP68 water and dustproof rating (2 meters submersible)
• Shockproof up to 2 meters
Specifications:
Length: 117.5 mm (4.63")
Head diameter: 26.8 mm (1.06")
Tube diameter: 21.4 mm (0.84")
Tail diameter: 24.4 mm (0.96")
Weight: 64 g (2.26 oz) (battery not included)
Warranty Service
The defective product can be exchanged for a replacement through a local distributor/dealer within 15 days of purchase. After that, all defective/malfunctioning NITECORE® products can be repaired free of charge within 60 months from the date of purchase. Beyond 60 months, a limited warranty applies, covering the cost of labor and maintenance, but not the cost of accessories or spare parts.
Immagine
Immagine
Nitecore MT2C Pro arrives in a small Black/Yellow cardboard box with writings that report the main features that distinguish it. Inside the package we find, in addition to the Nitecore MT2C Pro with the Clip installed and with the Nitecore NL1836R lithium battery inside, the USB-C charging cable, the lanyard, spare O-ring, manual and warranty.
Immagine
Immagine
The Nitecore MT2C Pro is constructed from aluminum alloy with a military-grade HA III hard anodized finish. The body design is similar to Nitecore’s recent products, featuring a thick texture that gives the MT2C Pro a noticeable grip to maintain a secure hold even with sweaty, wet hands or when wearing gloves.
Immagine
Immagine
The total length is 117.5mm with a weight, with battery and Clip, of 115g. Nitecore MT2C Pro is sold with the Clip already installed (but detachable), held by three removable screws, longer than half of the new EDC. Nitecore MT2C Pro fits well in a pocket or jeans given its small size and weight. Thanks to the tail design Nitecore MT2C Pro can be placed upright (candle-style).
Immagine
Immagine
Immagine
**The rechargeable lithium-ion battery NL1836R, found in the sales package, is a Nitecore in 18650 format with 3600mAh (NL1836R) with a continuous discharge current of 6A, equipped with a USB-C charging port. With this battery the maximum autonomy reaches 28 hours. Nitecore MT2C Pro can also be powered by other batteries in 18650 format, both protected and unprotected, or by 2 CR123/RCR123 batteries.
Immagine
The full charge time, measured in my tests, is approximately 4h10min. (Charging via 5V/1A adapter). During the charging process, the red charging indicator lights up constantly. When the battery is fully charged, the charging indicator turns solid green.
Immagine
At the two poles, for contact with the battery, we find a plated button on the positive and a spring on the negative. Nitecore MT2C Pro has electronic protection against reverse polarity and waterproof and dustproof classification according to IP68.
Immagine
On the head of the Nitecore MT2C Pro we find a smooth bezel and optical lens with anti-scratch coating on both sides with “PDOT” technology. The LED used is a NiteLab UHi 20 with a maximum power of 1,800 lumens.
Immagine
Immagine
The Nitecore MT2C has a single switch at the tail. The rubber button is a decent size with a perceptible click and a decent resistance to pressure. At the tail we also find the space to insert the supplied lanyard.
Immagine
USER INTERFACE (UI)
Immagine
The Nitecore MT2C Pro has a simple user interface with only two light levels that can be activated via the switch at the tail. Personally, I would have appreciated an intermediate level of 500 or 600 lumens, in addition to the two available, for better management of the light output.
NL1836R:
HIGH: 1800 lumens, 2h15min
LOW: 50 lumens, 28h
CR123:
HIGH: 800 lumens, 2h45min
LOW: 50 lumens, 20h
Instructions for Use
Momentary Tactical Illumination
For HIGH (default): When the light is off, press and hold the power button halfway to momentarily access HIGH. Release it to turn it off.
For LOW: Turn off HIGH, then press and hold the power button halfway within 2 seconds to momentarily enter LOW. Release to turn off.
Note: If the light is off for more than 2 seconds, pressing and holding the power button again will automatically return to HIGH.
Turning On and Off
Turning On:
For HIGH (Default): When the light is off, press the power button all the way until you hear a click to enter HIGH.
For LOW: Turn off HIGH, then press the power button all the way again within 2 seconds to enter LOW. Turning Off: When the light is on, press the power button all the way until you hear a click to turn it off.
Note: If the light is off for more than 2 seconds, pressing the power button all the way again will automatically return to HIGH.
ATR (Advanced Temperature Regulation)
The built-in ATR technology adjusts the MT2A Pro’s output based on working conditions and the surrounding environment to maintain optimal performance.
Immagine
BEAM and RUNTIME
Immagine
The beam is clean without artifacts with a white color with a slight green cast (corona). The illumination angle is not wide with peripheral illumination starting after about 1 meter.
Immagine
From tests done with the OPPLE Light Master Pro, at about one meter away from the sensor, the value of the CCT color temperature and the color rendering Ra, in the High level (1800 lumens), are respectively 5712 for the CCT and 62.8 for the Ra. The calculated Duv is equal to 0.0134. No PWM visible to the naked eye.
Immagine
Nitecore MT2C Pro with the NiteLab Uhi 20 LED, despite its small size, has a powerful beam with a very bright hotspot and spill. The candela values ​​(lux/1 meter), found by me with measurements at 3 and 5 meters are however lower than those “in the table”.
HIGH 1800 lumens:
Peak: 61,420cd
30 seconds: 56,800cd
LOW 50 lumens:
30 seconds: 2025cd
Immagine
Immagine
The Runtimes were done indoors at a temperature of about 22°C, using the supplied battery (a 3600mAh 18650) fully charged and two VARTA CR123A batteries (3V).
I would like to point out that the values ​​expressed in the graphs should be considered primarily as a reference because they were made with means and conditions different from those used in the laboratory.
With the High level, 1800 lumens, there is a sudden drop in brightness after 30 seconds from start-up. Subsequently, there is a slow decrease for over 17 minutes before the light intensity stabilizes at about a third of the initial one for over two hours before another drop that brings the brightness to the low level of 50 lumens. Nitecore MT2C Pro turned off after over 5 hours from start-up.
Another test was done by powering the MT2C Pro with two RC123A primary batteries (VARTA, 3.32V).
With these batteries the high brightness is 800 lumens at start-up. Immediately after switching on there is a small increase in brightness for about 2min30sec before a sharp drop for over five minutes after starting. At this point the brightness stabilizes for almost two hours before decreasing due to the exhaustion of the two batteries that power it.
Immagine
The first 20 minutes:
Immagine
Video Unboxing and Use
CONCLUSIONS
Nitecore MT2C Pro is a small EDC torch but with a surprising beam; powerful with a very bright Spot and Spill.
Excellent construction as always and in general no problems encountered. The package is complete with a rechargeable battery in 18650 format that allows the MT2C Pro to have a decent autonomy in the high level of 1800 lumens.
The new Nitecore can also be powered by other non-proprietary batteries, something always appreciated by everyone.
One note concerns the user interface with only two light levels. An additional level of 500 or 600 lumens, in addition to the two available, would have brought the benefit of better usability of the same.
Immagine
------ My YOUTUBE Channel ------------------------------------------------
Immagine
Big question is how long will it run on high? Is it going to step down after a minute or is it going to stay at that brightness?
I have write: With the High level, 1800 lumens, there is a sudden drop in brightness after 30 seconds from start-up.
Thanks for the video.
Fantastic flashlight.
My current EDC … :beers:
@ slope
I got it. Thanks for your answer
Nitecore must have read that 90% of us hate proprietary batteries and listened.
Nice light and perfect price point.
