Features
- Utilizes a CREE XHP70 LED
- Driven by a dedicated IMR 18650 battery to emit up to 2,800 lumens brightness
- Ultra-bright dual-mode tactical blaze
- Dual-switch tail cap designed for tactical use and easy application
- Mode 1 Suppressing light: Direct access to turbo mode
- Mode 2 STROBE READYTM: Direct access to Strobe Mode (Chinese Patent:201320545349.4)
- Four easily accessible brightness levels and memory function for fast boost
- Maximum beam intensity up to 21,000cd
- Extensive runtime up to 30 hours
- 289 meters far throw
- Integrated metal micro textured reflector for optimal peripheral illumination
- A power indicator LED hidden in the tail switch indicates battery power
- Electric reverse polarity protection
- Temperature regulation and protection
- Anti-rolling design
- Toughened ultra-clear mineral glass with anti-reflective coating
- Constructed from aero grade aluminum alloy
- Robust HAIII military grade hard-anodized
- Waterproof in accordance with IPX-8
Dimensions
- Length: 6.25” (159mm)
- Head Diameter: 1.57”(40mm)
- Tail Diameter: 1.18” (30mm)
- Weight: 7.52oz (213g)(without battery)
Features
- Rechargeable searchlight
- Utilises 4 CREE XHP35 HI LEDs, max output up to 6000 lumens
- Powered by 4 18650 batteries, compatible with li-ion/IMR batteries
- Max runtime up to 1000 hours
- Max throw up to 655 metres
- Onboard OLED display provides real-time data for brightness, battery power, voltage
- Reflectors with PDOT incorporated
- Intelligent charging circuit
- Temperature regulation to prevent overheating
- 5 brightness levels and 3 special functions available
- Dual-stage multi-functional single switch provides access to all functions
- Built-in power indicator to report battery level (Patent No. ZL201220057767.4)
- Onboard tripod receptacle
- Mineral optic lenses with anti-reflective coating
- Retaining rings protect core components from damages
- Made from aerospace grade aluminium alloy
- HAIII hard anodising
- Waterproof in accordance with IPX8 (2 metres submersible)
- Tail stand
Dimensions
- Length: 5.59”
- Head: 2.23”x 2.23” (Height/Width)
- Tail diameter: 1.97”
- Weight: 14.6oz (battery excluded)
Arrival of monsters expected by mid of April.
The price will be competitive.
Post in the topic of your interest, not in the PM!
