I just got at Nitecore UM4, and I’m testing it out with some brand new Tenergy Premium NiMH C-sized cells.
I have no experience charging C-sized cells. I usually charge AA and AAA Eneloops using a Gyrfalcon All-88. I often put it on 0.1A, and it seems to work fine.
I’ve found that the Nitecore UM4 will just go forever (like 20 hours) on 300mA. It eventually seems to stop right at 20 hours, maybe because of a fail-safe timer.
At 500mA, it also seems to go for quite a long time. I have one cell on there now, and it’s been going for 6+ hours at this point.
As a sanity check, I tried charging some Eneloops on the UM4 and Gyrfalcon in parallel. I did 300mA on the UM4 and 0.25A on the Gyrfalcon. Both worked and terminated just fine (the UM4 was slightly faster, as expected). Several hours later, the two test AA Eneloops are at 1.423V and 1.420V. Good stuff.
Then I put brand new C-sized Tenergy Premium NiMH cells on each at 500mA.
The Gyrfalcon finished at 4:19. The UM4 is still going at 6:12. I will let it keep going to see what happens.
Do you think it’s that there’s not enough current at 500mA to get a proper -dV/dt drop at the end?
I’m guessing that charging at 1.0A would work better on the UM4…
But then why does the Gyrfalcon not have this problem? Is it simply a better and more sensitive charger?
As a matter of habit, I generally charge Eneloop AA at 0.1A on the Gyrfalcon. I have noticed that sometimes, it goes 10:00 and then stops. Now I’m realizing that it’s probably failing to -dV/dt terminate when that happens.
I guess I should charge them at 0.25 always then? They do get warm when I do that, but now I understand that the warmth is what triggers the voltage drop in the first place.
(And if the Gyrfalcon is fine, why bother with the UM4? I need a USB charger for a solar setup that I’m working on).
