Noctigon KR1AA .1 LED Flashlight - Initial Experience
Couldn’t find much about this seemingly excellent little flashlight. So thought my initial user experience might be helpful to others.
But first, let me start with another AA sized LED flashlight, my favorite, the NiteCore D11.2. I love my D11. Even did a write up about it. I used that little ramping output light for so many things: test lab prep and result inspection, late night checks on the cats, walking in dark parking lots, looking under furniture, power outages at home and work, plus so many more things. It was small enough to be my constant EDC companion. Always with me, day or night. Even powered by a 14505, it only occasionally let me down in one, crucial, area - overall brightness.
I’ve tried other newer, brighter AA lights. None were quite right. Certainly not worth a full post. However, the KR1AA may be.
I got two KR1AA.1s from, “https://jlhawaii808.com”. Without knowing, screwed up my order, and was immediately help out by Jackson Lee, the J and L of JLHawaii (JLH). You concluded that correctly, Jackson took the time to helped me before I even knew I had caused a problem with my own order. Gotta say, Jackson has earned the reputation touted about him on the flashlight forums.
As previously alluded to, communication was excellent. This was from that start. Jackson preemptively put a “Please Read” section on the KR1AA page. From button, to body, to emitter - choices / variations were (and are) greatly varied. Packaging was first rate. And shipping fast. The: heads, tails, and bezels were all put on without being over tightened. They could all be easily manipulated without special tools or techniques.
Both lights were ordered with 14500 batteries. Both lights showed their batteries to be at 3.8 Volts. The lights arrived good-to-go! Especially as a flashlight enthusiast, this was much appreciated. It meant I could “play” with my new lights right away. Even though it was a fairly bright early afternoon, play I did. Noticed a few wonderful things. Also noticed a few small things and immediately found their easy corrections on my own.
Let’s start with the wonderful things. For me, the grip and size is only second to the diamond knurling and tubular form of the NC D10. Of course KR1AA bodies have the machine finishing step EMISAR NOCTIGON is known for. A continuous shallow line, with a tight filar, spiraling around the entire body. They also have what I believe is a new “chalky” finish. These two things, in perfect combination, make the KR1AA quite enjoyably grippable. And, less of a pocket shredder. The metal button allows for table- standing. Its throw is longer, not as crisp, and requiring more force than my TS10. This should help mitigate accidental activation.
I noticed the captured clip (my favorite style) of one light was a little looser than the other. Both clips were quite readily secured by simply: removing the head and battery. Then first slightly unscrewing then re-tightening the tail. Reinstalling the battery. And lastly, replacing the head. All was done by hand. I might have been a little too cautious when replacing the head. I did not press firmly, purposefully enough against the spring tension to seat the head. Making it flash like an electrostatic generator in a lightening storm! I believe this caused a self induced unintentional programming problem. For, oddly enough, the emitter of that same flashlight would only initially turn on and off. And, the ancillary RGB LEDs would only perform a fixed colour cycle. This condition was easily remedied with a quick factory reset.
Please note, these are just first impressions and experiences. Neither of the lights has had any pocket time. Though I will note, one of my cats HAD to knock the initially slightly problematic light off my desk as I was writing this. There seems to be no ill effect from the single fall directly onto a hardwood floor. Not even a scratch!
Interested to see and learn more about others’ experiences with the little EMISAR NOCTIGON KR1AA.1. Hope this thread gets added to.
11 Thanks
Thanks for your post, and for your impressions of the Kr1aa button compared to the Ts10.
Most reports agree w your assessment that the Kr1AA button is not overly sensitive.
It is also possible to modify the Kr1AA button to further reduce sensitivity.
Im hoping to get a Kr1AA to form my own opinion once V2 comes out.
I find the TS10 button not overly sensitive, so Im happy to hear the Kr1AA button is similar.
I carry a TS10 by itself, not with keys in the same pocket. The TS10 does not turn on in my pocket
After a few days of pocket time, noticed both the NTG50 5000K and the FFL5009R 5000K colour shifted with heat and output. Definitely rosier when cold and / or at lower outputs.
Also, the beam can catch off of the inside of a cupped hand and change tint. Wish the KR1AA was as long as the NC D11.2.
when the beams are compared side by side is one noticeably more rosy than the other?
can you post a photo to show the difference please?
The Nitecore D10 size and knurling were sublime.
I wish Nitecore would introduce an updated D10 or D11 with ramping UI or Anduril and a modern emitter.
Yes! Agreed!
KR1AA beam colours . . . (from this thread: KR1AA beam is looking good)
I don’t have brightness quite matched, but NTG50 5000K on the Left and FFL5009R 5000K on the right.
Like in the picture, the left side is a bit rosy in real life. But not so much it makes me want to throw up.
The right side shows a bit green in the picture, but is a bit creamy in real life.
Wurkkos TS10 SG v/s NOCTIGON KR1AA beam
Wurkkos TS10 SG, SFT-25R 6000K, TIR on the left. Not green, but white in real life. With rings and “petals” more visible than shown in the comparison picture. More concentrated hot-spot with larger corona.
NOCTIGON KR1AA, TIR, FFL5009R 5000K on the right. Not quite as rosy in real life. Larger beam, but more uniform in real life than the picture shows.
KR1AA .1 v/s D11.2 lengths. (Backed by a 4" X 6" card.)
EN KR1AA.1 left and NC D11.2 right.
AA light family length photo (Ascending heights from Left to Right.)
Wurkkos TS10, Wurkkos TS10 SG, Wurkkos TS10 Brass/Ti, LuminTop FWAA, LuminTop FW1AA, NOCTIGON KR1AA.1, NiteCore D11.2
8 Thanks
Somebody said they would prefer the KR1AA to be longer. Well different strokes. I would just as soon have it be the length of the FWAA or TS10.
Thanks for the beam shots and comparison sizes.
Can’t agree with you more. Back when I was searching for (yet another) NC D11.2, I emailed NiteCore and asked two things. One, for a list of distributors / sellers. Two, if they would consider making an updated version. I don’t remember if I got any names. But I remember getting a response stating the D11 was discontinued and was no longer to be produced.
Since December 12th, I’ve been using the black KR1AA.1 from the picture as my primary light - night and day. I used it for both work and personal use. Per the light’s uncalibrated voltage check, I received the flat top lithium rechargeable battery at 3.8 Volts. Only this weekend did high start stepping down. LVP turned on at 2.9 Volts. I checked, and the KR1AA ran off of a normal AA button top battery. After over a decade, I think I may have found a replacement for my NC D11.2.
6 Thanks
The body ridges actually make it more comfortable to cigar than the ts10! I thought i would dislike them, but they’re actually quite nice!
This is a great shout, this kind of thing is what BLF Special Editions are for, in my opinion.
Agreed.
The black KR1AA is actually the most comfortable light to cigar-grip I own. Due to the ridges, contoured shape, rough anodizing and size it feels very secure between the fingers. It is more comfortable to cigar-grip than the FWAA, TS10, FW3A and KR4.
However, I do prefer the increased pressure required to activate the switch in my o-ring modded V1 KR1AAs. They require around 1600g pressure to activate each… more than three times that of a stock KR1AA. No need to lockout the modded V1 lights. They aren’t going to activate accidentally in the pocket or when clipping/unclipping.
My unmodded V2 KR1AA gets lesser marks for comfort simply because there is a high probability of accidental activation unless lockout is used. That’s not the case with the TS10 (which requires almost twice as much pressure to activate) or the FWAA (which can be modded for much higher pressure).
is the V2 switch design different than the V1? (any chance you have photos?)
I haven’t actually opened them both up at the same time to compare side-by-side.
However, I suspect there is a difference, because when I tried the same o-ring mod on my V2 using the same size o-ring, it was unsuccessful. There was no noticeable difference in pressure from the unmodified light. I then tried various different o-rings and was unable to find any combo that increased resistance in the V2’s switch.
I think the V2 might use a different popper that is a bit wider and less conducive to the o-ring mod. However, it is possible that my dramatically different results between V2 and V1 with this this mod were just random variation due to small sample size and the tailcap is the same.
fwiw I agree with your switch pressure ballpark measurements
I get 526g for my stock KR1AA V1 switch
and 1030g for my stock TS10 V2 switch
From my measurements on my digital postal scale a couple weeks ago, I got the following measurements to activate the switch in various lights:
  • KR1AA V2 bronze (unmodified): 460g
  • Wurkkos TS10 (unmodified): 750g
  • FW3A (using early production run higher pressure popper, plus o-ring mod to switch): 1390g
  • KR1AA V1 black (modified with 9x1.5mm o-ring added to switch): 1590g
  • KR1AA V1 blue (modified with 9x1.5mm o-ring added to switch): 1690g
is your TS10 a V1?
TS10 changed to a new switch type in later part of V2
I get 850g for V1 TS10 which uses a dome switch (popper),
my V2 TS10 that has an electronic button switch has higher resistance of 1030g
in any case, we are getting similar results for the stock KR1AA.. it has a Low switch resistance.. you got 460g and I got 526g
Im getting similar numbers with my ts10v2 and kr1aa.
***measured with a cheapo amazon bought stainless fruit scale
