I just had to buy the great amazing large, tiny light from the big Wang (oh god the shadow warrior memories…) . And I also have a nitecore tm06s incoming and I hope to be doing some runtime tests at slightly lower levels on them both with hopefully the exact same batteries.
I will do a comparison when I have them both. Should get the nitecore this week but since it’s a christmasgift for me (yes had to order it myself ) will be a while before I can try it out. And will probably be closer to a month before I the meteor lands. But I’ll post a comparison and try to do a runtime comparison at around 1500/480 lumens and maybe 160. Mostly because it’s so hard to find info on lower levels with the meteor so I feel compelled to test myself because I need to know!
Unfortunately it’s only tested in turbo mode. But I looked at selfbuilts review of the original TM06 and the 4 hours runtime at high is more like 2 hours 47 min to 50% And the output starts falling at just over 100 minutes… Not very impressive and I suspect the new one will be about the same. The more I look into both lights the more I’m happy that I bought the meteor.
Only problem now it that I’m stuck in what batteries to buy… Going by what’s in stock at nkon I’ll probably get the NCR18650GA or INR18650-30Q Is the turbo mode regulated in brightness by how much power the battery can deliver?
Yes, it does affect the amount of lumens. But between those two the difference is slim, so I doubt that you will be able to see it unless you have them side by side.
I got same value with ceiling bounce test with both cells. Are you sure about this? The boost driver “pulls” the required amps from the cells; with tha GA you have a bit more voltage sag than with 30Q, so the driver corrects this to deliver the required power/amps to the ledboard.
No, since I haven’t measured it I’m not sure there is much of a difference between those two specific cells. But I have measured quite significant differences in light output on turbo between other cells in the M43.
Hmmm… interesting. I only tested the GA and 30Q, and you have the 25R and what other cells? I’m gone for the week, so can’t do tests…
I also tested to what point the cells can deliver full turbo output. With GA it was until cell voltage was 3.50V, and with 30Q until 3.45V. So I figured it doesn’t matter what cells you use as long they can handle about 10A.
