noctigon star
What is the best and easiest way to stick a noctigon star to brass pill
If the light has a reflector, you can use the reflector to press the star to the pill.
  1. Apply a thin layer of thermal grease between the star and the pill.
  2. Press the star into position.
  3. Solder the driver wires to it.
  4. If using an aluminum or metalicized plastic reflector, place an insulator on top of the pill or bottom of the reflector to prevent the reflector shorting across the pill. An isolator disk, Kapton tape, or arctic alumina thermal adhesive all work for this purpose.
  5. Place the reflector on top, then the lens then screw in the bezel tightly using the reflector to press the star into position.
If it’s an aspheric light without a reflector:
Some aspherics come with a plastic ring and disk that keeps the stock star in place. You can apply thermal grease and then see if you can reuse the ring and disk. This may not work because the Noctigon is probably thicker than the stock star.
  • Option 1: Glue the star in place. I apply a center dot of arctic alumina thermal epoxy directly below the emitter. I then surround this with thermal grease. I don’t glue the entire star down as then it wouldn’t be removable. With a small amount of epoxy in the center the star can still be removed by rotating it with needle nosed pliers to break the epoxy.
  • Option 2: Use a pin-vise drill to drill small holes through the star and into the pill. Then use tiny machine screws to screw the star into place after applying a thin layer of thermal grease. This method requires more materials but does a better job and is more easily removed than Option 1.
easiest: Arctic ceramique
best (thermally): solder it with solder paste and a torch
I see there is thermal grease, glue and all kinds of stuff. should the star be held down permanently with some kind of glue or just the pressure of the reflector holding it in place. I am trying this on an hs-802 pill. Is heat going to destroy this with out all kins of heat sinking. Xp-e2 with 1.9A driver.
If you’re using a light with a reflector then just the pressure from the reflector is more than enough.
The only time you really need to worry about gluing or screwing it down is if you’re using a light without a reflector.
Soldering the star to the pill gives the most secure connection and best thermal conductivity, but is probably overkill on most lights.
