NTSB blames bad battery design—and bad management—in Boeing 787 fires
Maker of lithium-ion batteries didn’t foresee spreading short circuit danger.
by Sean Gallagher - Dec 2 2014, 11:15am HST
38
NTSB Investigator Mike Bauer inside the aft electronics bay of the JAL Boeing 787 that caught fire at Boston’s Logan International Airport in January of 2013.
National Transportation Safety Board
Bad battery design and bad engineering practices were to blame for the fire aboard a Japan Airlines Boeing 787 in Boston in 2013, according to a final report (PDF) on the incident issued by the National Transportation Safety Board (NTSB) yesterday. The NTSB found fault not only with the manufacturer of the battery, but with Boeing and the Federal Aviation Administration (FAA).
In a prepared statement, NTSB Acting Chairman Christopher A. Hart said, “The investigation identified deficiencies in the design and certification processes that should have prevented an outcome like this. Fortunately, this incident occurred while the airplane was on the ground and with firefighters immediately available.”
There are two battery systems aboard the 787: the “main battery” in the front of the aircraft, which powers the 787’s ground maintenance systems and provides backup power to the aircraft’s control systems, and another set in the aft end of the aircraft used to start up the 787’s auxiliary power unit (APU), a small turbine engine in the aircraft’s tail which provides electrical power. Both systems used the same types of lithium-ion batteries manufactured by the Japanese firm GS Yuasa. And while the APU batteries were at fault in the Boston fire, a main battery caught fire two weeks later on an All Nippon Airways flight in Japan.
Thermal runaway
Both fires were the result of “thermal runaway”—the batteries became overheated to the point where a chemical reaction was triggered that released even more heat, causing a cascading effect that caused the batteries to explode or catch fire. Because of the fire hazard associated with lithium-ion batteries, there have been concerns about them being carried on airplanes—let alone being used as part of their electrical system—since 2004, when a battery caused a fire on a FedEx cargo plane.
In its report on the Boston fire, the NTSB cited thermal runaway as the cause, finding “[s]afety issues related to cell internal short circuiting and the potential for thermal runaway of one or more battery cells, fire, explosion, and flammable electrolyte release; cell manufacturing defects and oversight of cell manufacturing processes.” There were also concerns over the engineering that went into “thermal management” of the “large format” lithium-ion batteries aboard the aircraft.
Thermal runaway can be caused in a number of ways—most of them related to a short circuit within the battery itself. Manufacturing errors, including deformations caused in assembly and poor quality control, can create conditions which lead to internal short circuits in lithium-ion batteries, as can the swelling and shrinking of battery cells as they are charged and discharged. An analysis of the batteries involved in the fire found evidence of lithium metal deposits called lithium dendrites, which can grow over time from the battery’s anode and cause an internal short circuit, as well as reacting chemically with the battery cell’s electrolyte in a way that creates more heat. The dendrites were found to occur in wrinkles found in some of the electrolyte material formed while it was being wound—a serious quality control issue.
NTSB recruited Underwriters’ Laboratories (UL) to conduct a “short circuit abuse” test using cells of a battery provided by Boeing. The testing “showed that conduction of the heat generated by an internal short circuit in one winding of a parallel arrangement to adjacent windings could cause thermal damage in those windings and lead to thermal runaway of the entire cell,” the NTSB report noted.
Enlarge / A chart from the NTSB’s report, showing thermal runaway in tested cells of a Boeing 787 battery after an internal short.
But the NTSB also found shortcomings in the FAA’s guidance to manufacturers on factors to consider in safety assessments of equipment, as well as the agency’s guidance to its own certification engineers “to use during the type certification process to ensure compliance with applicable requirements.” And the NTSB cited problems with the 787’s enhanced flight data recorder, which resulted in “stale flight data and poor-quality audio recording.”
Failure to audit
Enlarge / NTSB Materials Engineer Matt Fox examines the casing from the battery involved in the Boston 787 fire.
NTSB
Part of what led to Boeing and the FAA failing to catch manufacturing issues at GS Yuasa was the way the 787 was built. The electrical systems for the 787 were outsourced to Thales, which in turn was responsible for managing each of its own suppliers and ensuring they met Boeing standards. But Thales apparently made some changes to things in its systems without a Boeing sign-off, and GS Yuasa made some changes of its own that deviated from Boeing and Thales’ instructions.
When the FAA and Boeing finally did perform audits on GS Yuasa, they found a raft of problems. The FAA found GS Yuasa’s operation wasn’t following instructions on battery component assembly and installation, wasn’t properly labeling parts, and that there was “no traceability [of component and assembly part markings] to assembly drawing and instructions,” according to the NTSB report.
Boeing found 17 specific issues. “Most of the noncompliance items at GS Yuasa involved adherence to written procedures and communication,” the NTSB report stated, and the “non-compliance items at Thales involved adherence to contractual requirements for Boeing’s approval on drawing or procedural changes.”
These issues will no doubt cause a chorus of “I told you so” from many—including some Boeing workers—who have opposed Boeing’s global approach to assembling the 787. By spreading the work into a modular process across multiple subcontractors and leaving only the final assembly of the aircraft to its own workforce, Boeing hoped to save significantly on manufacturing costs. But the battery problems as well as more recent issues with cracks in the wings of aircraft still in the assembly process have caused long delays in the 787’s full rollout, leaving customer airlines waiting and potentially costing Boeing billions of dollars in future sales.
Heat’em, cool’em, shake’em, zap them with high energy cosmic rays, abandon them in orbit — so as time goes by, problems arise ….
Same as always, nobody wants to admit to mistakes preferring to cover their ‘assets’ instead. What’s not being well told is that the failure-prone battery system is still in place albeit upgraded and ‘made safe’ in event of a failure, and that still happens occasionally. The thing is that these batteries are the only back-up should the main power system fail and without either, the plane’s computers die and so do all those onboard. They could have used the far more reliable NiMH technology everyone else uses, or even a larger and safer Lithium unit, but it would have cut into seating capacity so once again profits trump safety and reliability. A long comprehensive thread here about this subject: Professional Pilots Rumor Network I prefer Boeing but not this one- I’ll not ever get on a Dreamliner.
Phil
What size li-ions were these bad ones that they’re going to have to dump? I wonder how long it’ll take to re-wrap them and ebay them?
I think these are the batteries in question. They use a Lithuim/Cobalt technology which research by M.I.T. and other learned labs has shown to have an unusually high rate of sustaining thermal runaway once it starts. Boeing, seeking lightness, asked Yuasa to design these and they engineered the cell separators too thinly. The big problem was that with the size specs locked in they can’t substitute an alternate, as the designed battery area cannot be changed without re-entering the entire process of FAA design approval and airframe certification. That would take at least a year’s time and Boeing would be broke before the process was complete.
Airbus uses Li-ion batteries in some of it’s planes, but it’s a safer technology with heavier separators and they have had no major fires or excess failures. Boeing should have followed suit. Also partially to blame here was the Thales charging systems whose specifications allowed for too-rapid charging rates with no ‘sense’ circuitry to detect this particular problem. It too has been redesigned. This was Boeing’s first major foray into outsourced systems engineering and they simply didn’t watch the process closely enough.
BTW, Thales was formed largely from Lucas electrics- older British car and bike enthusiasts will know all about “The Prince of Darkness” moniker Lucas so deservedly earned.
Phil
