Here's pic of the driver removed. Size is 22MM. Don't know what that red stuff all over top is (bottom pic). Need to replace with compatible driver. Light uses 18650 or 2x123. I'd settle for 18650 ONLY as 123's ain't my thing. Light also has dual electronic switches, one for power and one for modes. Anyone know what would work in this light? My first transplant.
Switch is good. LED is good. Just no HI output. Should put out 1000 lumens. Putting out @25 lumens as it was.
The solder on the two 6 pin components (Q2 and U1) below the inductor look a bit suspect. I see 4 pins - 1 on bottom left of Q2 and 3 on left side of U1 that may not be properly soldered.
If you have a soldering iron with an extra fine tip I’d try touching up those solder joints and see if that fixes the problem.
