HELP, My old. 2016 I think, K01 is stuck on turbo. Does anyone know how to reset the driver to factor? Thanks.
I donβt own the light you mentioned so this suggestion might be totally useless. Some of my lights act the way you describe if the black lead to the emitter is shorted with the reflector. This can happen when you open the light and screw the bezel back in with too much force, causing the black insulator to tear. Or causing the reflector to touch the solder blob where the black lead is connected to the mcpcb. If this happens, apply some tape to the bottom of the reflector
That did the trick, thank you!
