Okay so anybody that’s been following the competition is probably aware there has been discussion surrounding categories and rules. This thread is to try and compile the sentiments of what should be acceptable in the fine print. For example should the use of pills be accepted in handmade? Should we make a new category for outsourcing actual construction of the light or components? Or a new category for builds under $50 ? If it entices more participation it’s worth considering. So if you have some input would like to re-write the rule book have a comment about the competition let’s hear it.
Here are the current rules for reference:
Rules of The 11th Annual Old Lumens Challenge:
CONTEST RULES:
You may enter a single build into one of the following three categories: (you are allowed to change categories during the contest)
- Hand Made (Basic Tools)
Your light must be made from scratch.
You must make a build thread, show images, and explain the build as it progresses towards completion.
No outside services are allowed.
Entries should be portable and battery operated.
All small hand tools are acceptable, as well as these power tools:
Soldering irons and other heating equipment
Electric drill / drill press
Dremel style rotary tool
Electric saws
Disc or belt sander
You may use some manufactured flashlight components: reflectors and other optics, drivers, LEDs and MCPCBs, O-rings, centering rings, springs, switches, switch boots, and pocket clips.
You may use any PCB whether you designed it or not, and you may acquire it from Osh Park or elsewhere.
You may use any firmware or code whether you wrote it or not.
You may not use manufactured flashlight parts such as a bezel, head, pill or drop-ins, body, or tail cap.
All kinds of raw materials can be used: sheet metal, wire, tubing and pipe, metal and plastic containers, bottles and jars, extrusions, wood, plastics, fabrics, epoxy, glass, stone, leather, rubber, etc.
- Machine Made (Advanced Tools)
All manually operated and computer controlled machine tools are allowed, such as:
Lathes
Milling Machines
3D Printers
As well as all hand tools and other fabrication equipment.
- Modified Light: (Anything Goes!)
You must show us something that was modified by you and how it was done.
You can make a new thread or link to a mod you have posted on BLF within the stated time frame of the contest.
You can build or modify by any means at your disposal and your mod can also be some form of self built flashlight attachment(s), clips, lanyards, paracord wraps, pouch, or other related paraphernalia.
If your build breaks the rules of the other categories, you may enter it in this category.
The following is related to the judging of entries and of prize selection:
JUDGES:
Contest organizers will solicit BLF members in order to find judges. The identities of the judges are not revealed.
JUDGING CRITERIA:
Up to 10 points are awarded in each of the following five categories:
Skill Level / Build Quality: Judged with consideration to the person’s access to tools, materials and abilities. Is the finished build functional looking good? Was it difficult to make? Was the craftsmanship top notch with the tools used?
Uniqueness / Inventiveness / Innovation: Is the light unique, one of a kind, or does it operate in a special way? Can something similar be readily purchased? Were new technical innovations introduced? Were new firmware, drivers, or PCBs created?
Build Thread Quality: Did the contestant do a good job of showing and explaining the steps involved in the build? Were the difficulties encountered along the way documented and resolved? Was it easy to follow along?
Shown Operational: Did the contestant show the light operating, describe its functions, take beam shots, videos, etc.?
Subjective Evaluation / Bonus Points: The judge may assign these points at their discretion.
PEOPLE’S CHOICE AWARDS:
There’s more than one way to win! In addition to the official judgement, a thread will be created which contains a poll, and the BLF community will vote for their favorite build. This poll will run for fourteen days. Contest participants may vote for other entrants but not for themselves.
PRIZE SELECTION:
The winner of the Hand Made category has 1st choice of prize, followed by winner of the Machine Made category, followed by winner of the Modified Light category.
Runner up of the Hand Made category has the 4th choice of prize, followed by runner up of the Machine Made category, followed by runner up of the Modified Light category. Prize selection will continue in this way as long as any prizes are left to award.
A special prize will be awarded to the winner of the people’s choice awards.
This is what the official scoresheet looks like:
