I got a Baton Pro and it seemed like a useful light, but with a few exceptions: the tint was too cool for me, the beam had some tint shift, and wooden furniture didn’t look natural under its low CRI light. To fix these issues, I decided to put four Nichia E21A R9080 4500K LEDs inside. From maukka’s measurements their CCT seemed to be nice around 4200-4400 K when behind a TIR optic and Duv seemed to stay negative on all modes.
After removing the bezel ring and optics I found there was XHP50.2 driven with 12 volts:
Looks like there was not much thermal paste under the MCPCB:
I’m wondering what is that shiny thing poking through the LED shelf. Is it a thermal sensor to protect the turbo mode from overheating? Here is a pic:
I had to file down the VR21SP4 MCPCB to make it fit inside the light. The VR21SP4 is only 0.1 mm thicker and 0.3 mm wider than the Baton Pro stock MCPCB, so it fits almost fine. It’s also made of aluminum, so it makes the light 4 grams lighter. I just had to make some holes for the wires:
The Baton Pro optic has a frosted surface on the inside of the LED cavity. I guess this should suppress the donut hole and reduce tint shift from the XHP50.2. Still it was not enough to remove all tint shift from the beam.
After trying the optic with 4x E21A, the beam had an ugly donut hole in the middle! The cause for this may be the darker area between the four LEDs:
To fix the donut hole, I sanded the outer surface of the optic with 400 grit sandpaper. This fixed the donut hole, and made the spill bright and very wide, about 170°. It also caused a 20 % lumen loss, and even a greater reduction in throw.
I like the result. Not as throwy or bright as originally, but now the tint is neutral and colors look great. This diffused beam is good for close-up work, no artifacts in the beam. After the mod I did a rough measurement with a phone app and got 1100 lumens on Turbo, and 360 lm on High. Here is a beamshot comparison with other modded Olights on Low mode:
Does anyone know where to buy a suitable optic for Baton Pro? I measured that it’s 21 mm in diameter and 12 mm tall with the white conical stent. Without the stent it’s 11 mm tall. Here’s my measurements (I also happened to use this modded Baton Pro as the light source when I took this photo):
I measured the current draw from a 4.0 volt bench power supply before the mod. And the lumens at start in an integrating sphere after the mod:
table(table#posts).
|Standby|38 µA|0 lm|
|Moon|7.8 mA|2 lm|
|Low|57 mA|19 lm|
|Med|0.22 A|78 lm|
|High|1.17 A|383 lm|
|Turbo|5.07 A|1270 lm|
I tried the Baton Pro with the Warrior Mini charger (MCC3), and I’m happy to see that it charges the Baton Pro at 1.5 A current. This means that Baton Pro can sustain the High mode indefinitely, when connected to the MCC3. The charger (MCC 1A) that came with Baton Pro only charges at 1A.
On continuous High mode, indoors in free air, this modded Baton Pro heats up to about 50 °C, or 27 °C above ambient temperature.
Link to the photo album.
